01-22-2013, 09:59 AM | #1 |
Q: on Manual Clutch Assembly
I'm running into an issue installing a hydraulic throwout bearing for a stock application into my chassis. I'm measuring about 1/4" interferrence fit between the clutch fingers, throwout bearing and the transmission.
Since this truck has a questionable history (very cobbled together over time), I do not know what friction plate/pressure plate combination is in it. Would a heavy duty pressure plate be thicker than stock? Is there a visual way to tell the difference between stock and heavy duty pressure plate with the cast bell housing installed and the dust shield removed? Thanks in advance for your help.
James "Bierkan" Vierkant 1950 3100 on a 1972 C10 Chassis Truck Blog Motorcycle Blog |
01-22-2013, 11:08 AM | #2 |
Re: Q: on Manual Clutch Assembly
Stock throwout bearings came in two different lengths to match the clutch. If you clutch took the shorter throwout bearing that could be the problem.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
01-22-2013, 11:27 AM | #3 |
The Older Generation
There are basically two different pressure plate configurations, diaphragm & Borg & Beck. If I remember correctly the diaphragm takes the long throwout bearing and the Borg & Beck takes the short one. Here is some info.
http://www.ramclutches.com/clutch%20u/cl_u_2.htm Here is another from Car Craft Mag. http://www.carcraft.com/techarticles...s/viewall.html LockDoc
01-22-2013, 12:02 PM | #4 |
Mine is a diaphram style.
01-22-2013, 01:35 PM | #5 |
Diaphram style came in raised finger and flat finger. Raised gets the shorter TOB.
FWIW there are 4 kinds of pressure plates. Borg and beck, diapram, long and long/borg&beck. |
01-22-2013, 03:03 PM | #6 |
I believe it's a raised finger diaphram style. Is there differences in the raised finger style regarding "height" of the fingers?
01-22-2013, 03:13 PM | #7 |
Not that I've seen.
01-22-2013, 03:29 PM | #8 |
Alrighty then. Looks like I'm returning a hto and finding something different.
