01-22-2013, 12:25 PM | #1 |
just ordered dropmember
I just ordered a porterbuilt dropmember and tubular control arms. Is any one runningthe rackand pinion withiout power I so how is this done. I was told I could just put a breather on the hoses and it would operate. Also anyone got ideas for getting the rear on the ground with stock trailing ams. Will flipping the rear crossmember do it? Thanks
Posted via Mobile Device |
01-22-2013, 12:57 PM | #2 | |
C10 CLUB Y QUE!
Re: just ordered dropmember
but you need larger you bolts. |
01-22-2013, 01:00 PM | #3 |
67-72 parts collector,…
Use a manual 79-93 mustang rack.
(not a power rack with no pump) Dino does it on all of his trucks.
01-22-2013, 01:08 PM | #4 | |
C10 CLUB Y QUE!
so theres a power and manual? |
01-22-2013, 01:10 PM | #5 |
01-22-2013, 01:15 PM | #6 |
http://www.unisteer.com/seach_by_veh...ard_ratio.html
http://www.unisteer.com/seach_by_veh..._bushings.html
01-22-2013, 01:20 PM | #7 |
Thanks a lot I already have 3" blocks on it. I need to get down about 4-5 more inches to lay out.
01-22-2013, 01:47 PM | #8 |
I would get the PorterBuilt trailing arms then. I am working on them myself. The stock arms are moving the axle forward and making the tire contact front of wheel well.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
01-22-2013, 02:03 PM | #9 | |
