Project Heaven in my 67!!!
Complete 71 2WD 5 lug suspension (front and rear)
Up for sale is the complete front cross member from rotor to rotor and the rear axle, trailing arms, and springs from a 71 Chevy LWB... Truck runs and drives as of right now but ripping the heart out of her because my built Small Block spun a bearing on the crank and it just seems like the right time to drop this big block in mine.
Rear Axle is a non-posi I believe 3.08 gears and the rear had the helper springs at one point but the PO cut the helpers off with a torch. Brackets are still there just no helper spring... These are local pickup only. $200 This is the truck that it is coming off of... |
Re: Complete 71 2WD 5 lug suspension (front and rear)
Would you separate the rearend?
Posted via Mobile Device |
Would you separate the rearend only?
Sorry gentlemen the parts sold locally!
