01-22-2013, 05:03 PM | #1 |
Angle strips on 65 chevy c-10
Hey guys. Removed my bed on the weekend to replace and the angle strips seem to be attached somehow. Cant see any obvious welds and no attatchment from the back, any ideas?
01-22-2013, 05:24 PM | #2 |
Re: Angle strips on 65 chevy c-10
About 30 spot welds per angle strip per side. Were welded from the outside of the bed panel prior to fender install
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
01-22-2013, 05:27 PM | #3 |
Crap. Whats the best way to remove? I have the new chrome strips to go in and need to remove these?
01-22-2013, 06:55 PM | #4 |
did you buy the angle strip covers or the actual strips. I know that Mar-k sells chrome covers.
01-22-2013, 07:28 PM | #5 |
Good question, bought them from Ecklers so i will check tonight!
01-22-2013, 08:25 PM | #6 |
I just tooka good stanley screwdriver and a 16 oz smasher wacker and went down the angle strip and banged out each spot weld. After removal, opened the holes to 1/4" with a drill, drilled matching holes in the new angle strips and bolted em on with some fender washers on the inside of the fender. Used a stainless allen head screw where they show in front of the fender.
01-22-2013, 08:28 PM | #7 | |
Scratch the rust a bit until you see where the spot weld is. Pry a putty knife under the strip near the spot weld to apply pressure from beneath the angle strip. Center the bit tip and slowly cut a circle around the weld. Once you go through the upper layer, the pressure from the putty knife will cause the angle strip to "pop" up, telling you to stop drilling. You will be left with a small dot of metal that you will grind off.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
01-22-2013, 10:08 PM | #8 | |
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
01-23-2013, 02:40 PM | #9 |
You guys rock, looks like a bunch more work than i anticipated but then again what isnt! Final question, if you are bolting the new angle strips does it leave any bolts showing on the exterior of the bedsides where the fender isnt? Taking in mind mine is the shortbed stepside.
01-23-2013, 07:45 PM | #10 | |
01-23-2013, 08:20 PM | #11 |
Im assuming that new bed sides dont come with angle strips attached?
01-23-2013, 08:35 PM | #12 |
Right, no angle strips on the new bed sides.
01-23-2013, 11:28 PM | #13 | |
01-24-2013, 11:08 AM | #14 | |
So it sounds like you cut all the way through the bedside with the spot weld cutter, right? Then you welded the strip and filled the hole at the same time. That will work! I kept thinking I'd have to use a spot welder (like the ones they sell at HF). I'm a novice welder, but I think I can handle this with my MIG.
01-24-2013, 03:47 PM | #15 |
62 did you get the steel angle strips or the chrome?
01-24-2013, 09:59 PM | #16 |
I bought steel to be painted. I thought about the chrome ones but I didn't know how to attach them. I didn't want to use screws and I wanted to look original. Once you weld them in you still have to use some filler to keep smooth it out. It can still warp easy so take your time. Here is before and after.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 Last edited by 62 Barnfind; 01-24-2013 at 10:09 PM. |
01-24-2013, 10:06 PM | #17 |
62 Barnfind,
Nice job on the restoration! I went through your build thread. How satisfied are you with the Hotrod Flatz Speed Blue as far as spaying and flatness? I like the color and was thinking of their powder blue. I'm a long way from painting. Nice job on the bed strips.
01-25-2013, 06:25 AM | #18 |
Thanks for the kind words, I have been working on this think for 1 year now. I like the final look when sprayed right. It is easy to run so yo have to spray light. It's easy to streak also if your gun is not set right. If I were doing it again I still would use it and I also would use the powder blue and use the one of the gold metallics for the inside. If you decide to do it a quart will work fine for that. I really like the satin look. I have to re do the front of the truck. I have streaks in it. I say do it. Just order the gallon kit.
01-25-2013, 01:05 PM | #19 |
62 barnfind, looks absolutely stunning. Does anybody know if you can spot weld or backfill chrome plated strips? And if so will the heat spots polish out?
01-25-2013, 01:43 PM | #20 |
You might ask that question in the Paint and bodywork section for an answer. I'd like to know too.
01-25-2013, 09:01 PM | #21 |
Thanks for the complement! I don't know that answer. I would think you could polish it out. I guess you could try it on something else first and see.
01-29-2013, 04:40 PM | #22 |
Ok, so decided to keep the angle strips in place until i do the complete tear down and replace the bed sides. I have got the gas tank installed, cnotch done and bed almost installed. Was going to upload some pics but wont let me for some reason.
02-01-2013, 02:22 PM | #23 |
02-01-2013, 02:24 PM | #24 |
http://s1311.beta.photobucket.com/user/Twodogsmarine/media/Chevy%20Truck/bracketfab_zps55cc34da.jpg.html?sort=3&o=4[/IMG]
02-02-2013, 01:35 PM | #25 |
Click on the image code on the right and it will copy. Then you paste the link and the picture will show.
