64 Parking Brake Lines
I am removing the factory transmission X-member and I am replacing it with the CPP tubular for a 700R4. I see that this poses a problem when mounting the parking brake cable mechanism. Is there an easy solution?
1964 Chevrolet C-10 SWB Fort Worth, TX |
Re: 64 Parking Brake Lines
Not sure about the easy part but, take a look at TR65's thread. Starting at post # 8. He has some pics of a parking brake mech. that he built. He is using a different trans, but maybe it will help.
http://67-72chevytrucks.com/vboard/s...d.php?t=413880
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. |
Hollister, CA.
![]() Join Date: Sep 2006
ANother option you might consider, which I thought was really neat....
On a customers 65 Nova, we used a e-brake cable kit from Lokar. Really nice long cut to length cables, and the attatchment to the OG main cable. I was thinking of going this route on my Burban ...
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
Hollister, CA.
Here are some pics of what I was talking about....
- - - ![]() - ![]() - ![]() - - I am not trying to endorse their product, but I just thought it was a really clean way of doing it. (however, it is available thru us ![]() The cable mount mounts very easily, and is small enough to fit anywhere. In this case, it was ran outside the frame connector, in line with the stock cable.
#5 | |
My truck ain't dead, it just smells funny. |
Hollister, CA.
No, both....
You can see the two cables in the pics Posted via Mobile Device
I bought a pre-made crossmember with the e-brake mount and added to it. Made just for our trucks.
http://www.bowtieoverdrives.com/cata...php?ITEMID=108 I canalbized the old crossmember parts from it. Used clevis pins, cotter keys, drilled, bent and made a brass bearing. I didn't use a spring. I have springs on each side on my rear disc brakes. Mocked up clears my 4L85E just fine. Yes I do have a powdercoat problem, my son suggested a 12 step program for me. |
Thank you for the complement. Lokar stuff is nice but I'm going for the semi hidden stock look. I also converted a 1985 c10 gas pedal with the cable. No more linkage. Modified the brake pedal, welded a 1985 c10 larger pedal up. But I have issues kept the old school pull up brake. Yep that's powdercoated too. Thank you once again. zpoppy
