![]() Join Date: Dec 2012
dash pad replacement
can't figure out how to reach nuts on out side corners of dash.
The Older Generation
Re: dash pad replacement
You just about have to remove the instrument cluster and glove box liner. I have removed them without doing it but couldn't get them back on. LockDoc
Remove instrument cluster and glovebox liner. Stand on your head. Cuss loudly for 20 minutes.
I wound up using a wobbly extension to reach those, but still needed the glovebox and the cluster out of the way.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
Active Member
![]() Join Date: Jul 2007
Easiest method as LockDoc mentioned. I have also used a flexible wire extension and/or a 1/4" u-joint swivel adapter. In some cases the end nuts are buggered up and won't come off. That's when it's cussing time. Last one I removed I actually had to pry the pad off and cut the small bolts off. It was a non salvegable pad anyway but still a pain.
Just read Lattimer's post... Zactly right! ![]()
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Oh joy. Really makes me want to replace mine now. Damn
Posted via Mobile Device |
Its not the worst job I have done, but its on the list of things I don't like doing. I'm a big guy and contorting myself into position to reach up under the dash is miserable.
#7 | |
Take out instrument panel and glove box. no other way. sounds like alot of work but not as time consuming as not doing it.
![]() Join Date: Oct 2009
always a good idea to figure out all the stuff you need/want to do while you have to take out these major access points anyway. Considering a factory tach addition, adding a vac gauge, a new gb liner, putting in that cherished am/fm picked from the parts board, etc etc? Now would be the time to knock it all out together. It is simple, but I agree, a paint in the butt if it's all you're doing.
#10 | |
The one above the radio is a real bear, unless of course you take the radio out. I didn't though, still got it done with glove box and cluster out.
71 K20 64 GMC mud truck |
flexible wire extension sounds like it will help some. Have been on head under dash many time trying work this out. Looks like no easy way to do this. thanks for help.
#13 |
Scrapper 1
the joys of working on these trucks.But look on the Bight side your not dealing with plastic 1990 chevy trucks the light switch with them 4 small screws the go into the plastic you brake them your in trouble light switch will not work with out them 4 little screws.Remember you will only be putting in 1 dash pad in the life of the truck unless you have smokers in your truck that like to Put there Cigs out on your dash pad or some one that like playing with there knife and likes to stab things.Plus you learn how to remove you cluster and your glove box.
Plus if gives you time to check all your bulbs in your cluster to make sure therte nice and bright and working |
#14 | |
#15 |
Scrapper 1
you say your a big guy witch way are you saying big tall wise or Big in the belly I'm 6'4 270 pounds and its not nice for me to work on anything in tight places LOL
#16 | |
![]() Posted via Mobile Device
-Bruton 1968 GMC long bed 5.7/700R4 --I'd rather push a Chevy, than drive a Ford.-- |
#17 |
![]() Join Date: Feb 2002
One time, after I got the old, flaky, sunburnt dashpad off and put the shiny new blue one in -- I tried for days to get one nut started on the first one on the Left [Drvr Sd]. I pulled it back out and found it had been threaded wrong or had some slag on the end of the threading from the buried bolt. I was pi$$ed. I sent it back to the vendor and got a new one with good threads embedded in the foam. But how was I to know I should have tried matching the nuts on all the new screws before I got on my head?
#18 | |
Both....unfortunately. 6'3", 390. I'm a former powerlifter and now I armwrestle competitively. This was my best bench back in the day.
#19 |
Active Member
Lattimer: Both....unfortunately. 6'3", 390. I'm a former powerlifter and now I armwrestle competitively.
Dang dude!! With your size it looks like it would be a tight squeeze getting in the door. And I though my football player son-in-law was big at 6'5" and 250.
#20 |
I actually surprise myself with some of the places I manage to fit. Those tiny bolts in hard to reach spots really give me fits.
#21 |
Moderator
![]() Join Date: May 2007
When you install your new pad make sure you do not over tighten the retaining nuts, otherwise you will end up with a dashpad that is warped and wavy across the top.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#22 | |
You don't bother carrying a jack in your truck, do you ? That 905 is phenomenal.
'67 K-20 longbed 4X4, 350, SM-420, Vortec heads, flat top 4-brow pistons, Eaton 4.55's, Qjet, MSD 8365, Comp XE250H, Dynomax duals |
#23 | |
#24 |
Scrapper 1
the hole reason why we own these trucks is cus there so easy to work on.Its so dam basic and plus they take us back in time and lets us relax.So be glad your not working on the 1989-2013 trucks them trucks you really stress out on.Just think almost every truck out there today they build the truck around the heater Core my 1996 ranger takes 5-6 hours to remove the dash to get to the heater core.l Now that is fun work for us big tall guys
#25 |
I am a Referee of life.
My big guy tip works well.Do seats at the same time.Take yours out to recover or clean.Do the dash pad then put the seats back in.Get a foam kneeling pad or pillow to help support your back while youu're twisting around under there.6' 280.
BTW if it's a bench seat 4 bolts ain't a bad deal for the room.Pull the cluster and such before the seats though.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
