Old 01-22-2013, 11:56 PM   #1
nitrosport_5
nitrosport_5's Avatar
Best way to cut for AC Vents?
Ive searched and really have not found a good way to get the correct hole for the factory AC Vents. I already have grafted in an AC firewall. I dont have a donor truck to take templates off of, so at the moment i am sitting with the factory ac vents, and a dash with no holes. Thanks in advance.
"Rusty" 1972 K20 Cheyenne Super, 496, A/C, Tilt, Tach, Buckets, 4l80e/NP205, 4" Rancho Lift, 35" BFG AT
"Ramp Truck" 1972 C30 Ramp Truck 350, Air Bags, Factory A/C.
"1968" C10 Shortbed project
nitrosport_5 is offline   Reply With Quote
Old 01-23-2013, 08:09 AM   #2
MARKDTN
Re: Best way to cut for AC Vents?
Measure 2-3 times cut once.
I used a drill then a jigsaw.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 01-23-2013, 08:35 AM   #3
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
http://www.vintageair.com/INSTRUCTIO...0A%2012.15.pdf. Go to pg. 23. Hope that helps.
TobyArnot is offline   Reply With Quote
Old 01-23-2013, 09:27 AM   #4
Lattimer
Lattimer's Avatar
I used a holesaw for the round vents and a drill and a dremel with cut off wheel for the center. I cut them small and then ground them with the dremel to get them to size.
Mine are repro parts from Classic Auto Air. The install manual for the system has a template for the center: http://www.classicautoair.com/?q=67_..._Chevy_AC.html
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 01-23-2013, 10:57 AM   #5
dznucks
dznucks's Avatar
I tried several options when i did mine and found the best thing to do is layout the hole location and scribe the circle on the dash panel. then drill a hole inside the circle and use a pnematic air saw cut the circle out. You probably wont be able to cut the entire circle at once, but you can cut peices out at a time. When you get close to your scribed mark, use a grinder like mentioned above to get to you final hole size.
I bought a hole saw for this, but it kept jumping and grabbing chipping the paint.
dznucks is offline   Reply With Quote
Old 01-23-2013, 11:06 AM   #6
Lattimer
Lattimer's Avatar
I went one size smaller on the holesaw, so even though it didn't cut real clean it didn't matter because I had to grind the hole to finish size anyways.
Did it last weekend, so its still fresh in my mind.
Shawn
