Old 01-23-2013, 12:16 AM   #1
71Longbed
Not Mine But A beauty
71Longbed's Avatar
Baggin?
who sells the least expensive kit that isnt total crap?
68 Chevy Shortbed 454/400
2000 Chevrolet Camaro SS 6spd
2011 Silverado 5.3 6spd auto
71Longbed is offline   Reply With Quote
Old 01-24-2013, 01:22 AM   #2
andrewmp6
Re: Baggin?
Depends a lot on do you want it lowered good or to lay frame.Or do you want manual valves or the electric ones?The cheapest kit i would use is http://www.azproperformance.com/Pro1...r-Bag-Kit.html that will get you pretty low if you want to lay frame the price goes up http://www.azproperformance.com/Pro3...-Ride-Kit.html
andrewmp6 is offline   Reply With Quote
Old 01-24-2013, 02:06 PM   #3
71Longbed
71Longbed's Avatar
Re: Baggin?
just want to go low not lay frame and i dont want to tub it or modify the wheel wells
Old 01-24-2013, 03:42 PM   #4
king-918
king-918's Avatar
Re: Baggin?
the real question is what do you consider to be cheap?
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 01-24-2013, 04:27 PM   #5
Pro Performance
Pro Performance's Avatar
Re: Baggin?
Our Pro1 kit is a great kit and has everything you need to install onto your truck, minus drop spindles. The reason we don't include those, is a lot of guys are converting over from a static drop and already have the spindles.
The Pro1 will get you a low stance when parked, and allow for a ride height that is similar to a static drop. We can offer the Pro1 with a manual air management system, depending on your budget and preference. If going electric valves, this allows for the addition of e-level at a later time.
These trucks are running the Stage1 front and Stage2 rear from Porterbuilt, which are the same components that come in our Pro1 kit.
Pro Performance is offline   Reply With Quote
Old 01-24-2013, 04:27 PM   #6
71Longbed
71Longbed's Avatar
Re: Baggin?
im trying to keep the cost down so the lower the better
maybe a better question would be what do i need and what dont i need?
totally new the the whole air bagging idea
Old 01-24-2013, 04:33 PM   #7
Pro Performance
Re: Baggin?
The Pro1 kit, using the Stage2 Basic Porterbuilt rear kit will include the adjustable trac bar, c-notch & shock relocation which are all the right components to do bag the the truck correctly. You can go with a simpler setup, without a c-notch or adjustable trac bar, but will not get quite as low and the rear end will see more movement through the suspension cycle. The adjustable trac bar helps center up the rear end and allow for minimal movement due to it being longer (and positioned lower) than the original. It will extend from the frame side, to the opossite trailing arm.
- Travis
Old 01-24-2013, 04:34 PM   #8
Pro Performance
Re: Baggin?
Porterbuilt Stage 1
Porterbuilt Stage 2 Basic
Old 01-25-2013, 12:44 AM   #9
cubber
Re: Baggin?
^^^What he said. I basically have their kit, but I pieced some stuff together. Would have been just as good, if not better off, to buy the kit.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 01-25-2013, 03:09 AM   #10
andrewmp6
Re: Baggin?
Pro Performance is one of our site vendors and is the cheapest i found i trust to buy off of.
