Old 01-23-2013, 02:04 AM   #1
jocko
jocko's Avatar
ambidextrous mirrors
can someone pls confirm yay or nay that the pictured DF2 camper mirrors are the same between left and right - i.e. can be mounted on either side... I have always assumed they are interchangeable left/right, but I've only ever owned one at a time... so wanted to confirm. Thx.
Old 01-23-2013, 03:11 AM   #2
Scott>72-GMC
Scott>72-GMC's Avatar
Re: ambidextrous mirrors
Looks that way
Scott>72-GMC is offline   Reply With Quote
Old 01-23-2013, 09:20 AM   #3
SS Tim
SS Tim's Avatar
Good question, I would have bet you a fuel selector bezel on that one and lost. They are different between left and right! As best I can determine the "brace assy." (triangle component) is handed. From pictures of a '71 (factory DF2) the difference appears to be that the forward tube is on top where everything bolts together at the swivel arm.
BTW: Jocko have you downloaded your parts manual yet? Learning it might be a good project when you are not in the shop. You can even use it to help your buddies with earlier models too. :-)
SS Tim is offline   Reply With Quote
Old 01-23-2013, 10:20 AM   #4
bruceman1968
bruceman1968's Avatar
I would give my right arm in order to be ambidextrous.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 01-23-2013, 10:34 AM   #5
68gmsee
Active Member
68gmsee's Avatar
.... I wish I had been. Doc says only thing they can do for mine is complete replacement.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 01-23-2013, 12:10 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Edit: Just gave my original mirrors a closer inspection. If there's any difference at all, I cannot see it or measure it. Drivers side has the forward triangulated tube on top; passenger side has the rearward tube on top. They appear to be identical. And of course the tube position is easily changed by unbolting and moving to the desired location.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 01-23-2013, 01:29 PM   #7
Tinkermc
in for daily driving out for towing they work great
Tinkermc is offline   Reply With Quote
Old 01-23-2013, 03:12 PM   #8
Ironhorse
Ironhorse's Avatar
Mark, I have those same mirrors on my '71 4x4 and I like'm. Big enough to see something in them but don't have the blind spot like from west coast styles. I added them to my truck when did the paint and body, can't say as I really noticed a difference in the mounting of them.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 01-23-2013, 04:33 PM   #9
jocko
jocko's Avatar
I got it...
Old 01-23-2013, 04:37 PM   #10
jocko
jocko's Avatar
Hmm, interesting. I guess the listing of separate part numbers doesn't guarantee they are different, but it sure would seem so. (Yep, I've downloaded my parts manual Tim - just thought for sure someone would know off the top of their head).
I appreciate you all looking at your own trucks, very helpful. Makes me want to go look at one in person and walk in circles around the truck...
Like I said, only have 1 right now. My "plan" which changes often is to mount the smaller tripod mirrors (same size head) but without the fold-out capability for when towing. I like the overall look of them better, and have spent a good amount of time tracking down the parts. But there's something to be said for keeping the truck original, I'm trying to do that everywhere else, but I initially hated the mondo-monster camper mirrors, but I have to admit they are growing on me... Thanks again gents, appreciate the help.
Old 01-23-2013, 09:44 PM   #11
SS Tim
SS Tim's Avatar
Hmm, interesting. I guess the listing of separate part numbers doesn't guarantee they are different, but it sure would seem so. (Yep, I've downloaded my parts manual Tim - just thought for sure someone would know off the top of their head)...
Really does not seem right that the tube ends are the only difference and enough to warrant a seperate part number. Is there any difference on the brace assy. tube angles going into the door?
The fact that it is reversible regardless of design intent could have resulted in a lot of trucks being missbuilt or the incorrect part being used in service.
Still a good question and as it appears they are reversible and correctable, can't do that often with handed parts. Be intersting to see if anyone has a service kit or instruction sheet though.
Old 01-23-2013, 10:40 PM   #12
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Tim, I looked at those downtubes also. They are the same length and bent at the same angle. If there's any difference, I couldn't find it.
- Mike -
RIP El Jay
Old 01-23-2013, 11:00 PM   #13
SS Tim
SS Tim's Avatar
Yes the four (between the two doors) down tubes are all the same part number. The difference might be the angles of the brace assy. itself moving the mirror head/arm slightly forward or back from centerline.
