Old 06-11-2003, 08:53 AM   #1
69_hafton
Sleep-Deprived
69_hafton's Avatar
limited slip vs posi differential
I'm just wondering after putting new gear oil in my diff, if a limited slip differential is different than a posi.
Mainly, do I need GM's limited slip additive in addition to the gear oil in my Eaton posi rear?
69_hafton is offline   Reply With Quote
Old 06-11-2003, 10:01 AM   #2
bpmcgee
bpmcgee's Avatar
Eaton posis have a very specific oil. I BELIEVE that all you need is this.
bpmcgee is offline   Reply With Quote
Old 06-11-2003, 10:50 AM   #3
chaptr2
chaptr2's Avatar
Limited slip and Posi are the same. "Posi-traction" is a GM term.
Yes you need to add gear oil or an attitive that is for Posi or limited slip differentials.
This is only my opinion and it is subject to change.
70 GMC Short box stepside Blown 388 Stroker
72 K/5 Blazer 350/SM465/205
chaptr2 is offline   Reply With Quote
Old 06-11-2003, 01:38 PM   #4
Alexis
Member since 2000
Alexis's Avatar
The additive only last a year. That what I was told, something about the add. being weaker then gear oil and the stuff that makes it work brakes down faster then regular gear oil.
Alexis is offline   Reply With Quote
