01-23-2013, 10:11 AM | #1 |
LS motor angle questions????
What part of the motor/transmission are you guys using to determine your motor angle? The back of a head? Transmission output shaft? Thanks in advance.
r
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-23-2013, 11:46 AM | #2 | |
Re: LS motor angle questions????
Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
01-23-2013, 12:11 PM | #3 |
Thanks Nate. I thought I had read that, but I wanted to make sure before I drilled any holes. What's the max and min angle when setting this?
01-23-2013, 12:15 PM | #4 | |
01-23-2013, 12:21 PM | #5 |
Cool. Forgot to mention, I will be running a 2 piece driveshaft.
01-28-2013, 09:09 AM | #6 |
Nate do you have any pictures or part number of the carrier bearing I should run with the 2-piece drive shaft? TIA
