Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-23-2013, 01:05 PM   #1
68racer
Yeah baby!
68racer's Avatar
Manual Master Cylinder
I know this has been covered before but I just want to check.
I want to convert from power brakes to a manual, which bore size should I go for 3/4 or 1 inch?
Also any reccommendations for which one to use?
I may have a deal on a Wilwood 3/4 inch.
Thanks,
Neil.
11.37 @116
68racer is offline   Reply With Quote
Old 01-23-2013, 02:24 PM   #2
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Manual Master Cylinder
It depends on what tye of brakes you have . I will post a few links for better info tonight .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 01-23-2013, 02:46 PM   #3
68racer
Yeah baby!
68racer's Avatar
Sorry forgot to say it is a '73 front clip with the HD discs, nine inch with drums on the back but I may put discs out there too.
11.37 @116
Old 01-24-2013, 12:14 AM   #4
Captainfab
60-66 Nut
Typically a manual master cylinder would have a 1" bore.
Old 01-24-2013, 08:26 AM   #5
Marv D
Registered Truck Offender
Marv D's Avatar
I tell ya, it's really hard to go wrong with one of these. I've used it on drum/drum, disk/drum and disk/disk with a proportioning valve and it's pretty darn foolproof. Just be sure and bench bleed it WELL before installing. I had to open up the holed in the firewall just a tad and did not use the adapter plates.
http://www.jegs.com/i/JEGS-Performan...31403/10002/-1
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 01-24-2013, 01:31 PM   #6
hotrod 80
mini truck racer
hotrod 80's Avatar
Sorry , busy night and all this info is on my computer at work . The Link Marv gave you is what i have minus the kit . I bought mine at the local auto parts and fabbed my own support plates .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 01-30-2013, 01:22 PM   #7
hotrod 80
mini truck racer
hotrod 80's Avatar
Sorry for the delay , here is the info .
http://www.thebrakeman.com/valvetechii
http://www.dragracingonline.com/tech...ers-print.html
http://www.performanceonline.com/blo...e-pedal-ratio/
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 01-31-2013, 06:18 PM   #8
68racer
Yeah baby!
68racer's Avatar
Thanks for that, lots of information. It looks like I am after a one inch bore master cylinder.
11.37 @116
