Old 01-23-2013, 04:16 PM   #1
solidaxel
solidaxel's Avatar
Casting numbers
Is there a way to tell EXACTLY what year and size LS engine and transmission I have.
Where are the numbers located?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-23-2013, 11:41 PM   #2
solidaxel
solidaxel's Avatar
Re: Casting numbers
Here are the numbers I located on the passenger rear just below the cyl. head cast iron block 12567392 there was no alpha in the casting number
LS 3 4L70E
Old 01-23-2013, 11:52 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Casting numbers
its a 5.3, and the only reason I found that is because of other peoples "what do I have threads", and they posted the same block number. but the block castings aren't used much to figure out what you've got...if its stock look at the number on the heads and its usually easier to figure out.
Your heads probably say 706 I think
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-24-2013, 12:17 AM   #4
solidaxel
solidaxel's Avatar
Re: Casting numbers
Thanks I will look for more numbers, (heads)
LS 3 4L70E
