01-23-2013, 04:57 PM | #1 |
Front brake hoses
Hi folks from Chula Vista Ca.
One of the upgrades I did on my C10 69 was: swap front disc brakes from a C10 1980,last night the driver side hose was broken because when the wheel turned to inside the caliper broke the hose against the lower arm. I'd like to see a picture, how the hose is installed, also where can I buy the right hose, the one I've on my truck was build to fit because if I use the 80 version the end to the caliper is right but the other end is 69 version Thank you |
01-23-2013, 09:08 PM | #2 |
Old member
Re: Front brake hoses
These are the S/S hoses I just installed.
01-24-2013, 01:35 PM | #3 |
Great!!! Thanks for the pictures. As I said the the hoses I installed were custom made and looking on your pictures I noticed mine are longest that's why are broken.
Thank you Andy |
01-24-2013, 02:10 PM | #4 |
Profe56
If you need a custom build stainless braided line contact Crown Performance in Vista. They are only about 30min north of you and they can custom build the lines. www.crownperformance.com phone. 760-599-0090 |
01-25-2013, 09:22 AM | #5 |
Old member
These guy's will custom make anything for you as well.Here is the thread I did mine in.
http://i.ebayimg.com/t/STAINLESS-BRAKE-HOSE-SET-Chevrolet-Truck-C10-1-2-Ton-1971-/00/s/NjM1WDEwMDA=/$(KGrHqF,!ncE8U7YKkNJBPL,(Gs2zQ~~60_12.JPG
01-25-2013, 12:50 PM | #6 |
Thank you Andy.
I'll just wait is not raining to start working. We expect rains all the weekend |
02-02-2013, 10:58 PM | #7 |
I already order a custom hose but
But I've this question. 71/72 calipers do fit on 73/87 spindles C10. May be this could be more easy to get the right hoses. When someone wants to swap 73/87 on 67=72 |
