01-23-2013, 07:06 PM | #1 |
Spring bushings
I hope you guys can help me one more time!I'm putting rear springs in my 72 K5 ,that are out of a 89 K5.Everything measures right and they should work,my problem is bushings.I went to replace them and I ordered them for the 89 first and them the 72 both are the wrong dia. the ones oreded are 1.50 and the ones I need are 1.62 give ore take.Any ideas??
01-23-2013, 07:22 PM | #2 |
Re: Spring bushings
We are a Prothane dealer and I looked up the spring bushing on a 89 truck. The largest they have is the 1.5" bushing. That 1.5" bushings is real loose in the spring eyelet?
Can you take a picture? |
01-23-2013, 09:11 PM | #3 |
Re: Spring bushings
Hope this helps,One bushing not removed yet,one out with the 1.50 bushing in there with room to put a car key down the side.
Dave |
01-24-2013, 12:33 AM | #4 |
At the body shop.
Re: Spring bushings
Look like newer 88/98 ck springs. Wonder if things were swapped around at GM? Check a newer bushing o.d
" That didnt make it any newer " " Dont antique the equipment " |
01-24-2013, 10:16 AM | #5 |
Re: Spring bushings
Think I found the right ones thru SDTrucksprings.com ,they seem to know all about it.Will know tomorrow for sure,thanks for the help.
Dave |
01-24-2013, 01:33 PM | #6 |
Re: Spring bushings
It seemed Prothane didn't have anything larger for that spring.
Glad you did find one that will work. |
