Where to buy pre-made vacuum line for th350?
Where can i buy a pre-made steel line for a th350 vacuum modulator to intake manifold? Or if i can get a hose, what is the best kind to use that wont suck in with the vacuum? Thanks
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear, 1968 C-10 SWB - 454 BB TH350 -Gone! |
Cluster King
![]() Join Date: Nov 2012
Re: Where to buy pre-made vacuum line for th350?
I am not sure if it is an aftermarket item or not. Any Chevy with a 350 trans, car or truck will have this line. You may have to tweak the end near the intake to line up with the fitting in the intakeor use a longer peice of rubber hose to connect. I would check out some local salvage yards or cars/trucks for parts on craigslist. I would not use rubber hose myself, just a personal thing. I think it is 3/16 inside diameter. You can also buy steel line at the parts store and cut and bend it yourself if all else fails.
Ordinary steel brake line will work with rubber ends and can be bent easy enough. I've used the larger dia stuff without issue.
Posted via Mobile Device |
Go
![]() Join Date: Oct 2010
I used 3/16 brake line and bent my own. Wasn't to hard to do.
Thx for all the responses
![]() Join Date: May 2010
Try The Right Stuff. Here are links:
1972 http://www.getdiscbrakes.com/ttv7201 1969-1970 http://www.getdiscbrakes.com/ttv6905 I don't see any listed on their website for 1971, 1968 and 1967. |
