Closed Thread
Old 01-23-2013, 11:40 PM   #1
RdoubleU
RdoubleU's Avatar
No Limit Front Sway Bar
No Limit Front Sway Bar for 67-72 C10
I just used this bar for mock-up before I changed over to Porterbuilt tubular lower arms and porterbuilt sway bar.
Kit comes with the end links to mount to both stock control arms and tubular arms with tabs.
Here is the thread with details about the bar (see post #306-308) http://67-72chevytrucks.com/vboard/s...436621&page=13
I do want to mention that I never squared away the bushing/mounting issue since I was only in mockup stages. No Limit sent with the kit 1" urethane bushings that are too small and I also have a set of factory style Moog bushings and GM brackets (Part #'s seen here: http://www.67-72chevytrucks.com/vboa...ad.php?t=72338) The bushings fit the bar but brackets were a little too short to not compress the bushings. Just wanted to mention that, but should not be an issue to figure out a solution.
Asking $150 + shipping
RdoubleU is offline
Old 01-26-2013, 02:04 AM   #2
RdoubleU
RdoubleU's Avatar
Re: No Limit Front Sway Bar
bump
RdoubleU is offline
Old 01-28-2013, 06:54 PM   #3
RdoubleU
RdoubleU's Avatar
bump
RdoubleU is offline
Old 02-01-2013, 10:23 PM   #4
RdoubleU
RdoubleU's Avatar
Bump
RdoubleU is offline
Old 02-14-2013, 12:42 AM   #5
RdoubleU
RdoubleU's Avatar
bump
RdoubleU is offline
Old 03-01-2013, 12:08 AM   #6
RdoubleU
RdoubleU's Avatar
ttt
RdoubleU is offline
Closed Thread
