Old 01-24-2013, 12:02 AM   #1
Jdubs71
Jdubs71's Avatar
04 5.3L What is it worth
I thought I would try here first since this is where all the lsx knowledge is. I have been going back and forth with my k5 build and have decided to go with rebuilding the stock motor. I'm trying to budget wisely and since I have a rebuilt th350 and np 205 it just makes fiscal sense to use them. I have weighed and priced out the options with what I have for the 350 vs. what I will need for the lsx swap and its a pretty big difference in costs.
So here goes, I have an 04 5.3 LM7 with under 40k mi. I have the harness ecm and dbw pedal/module. Can you guys give me an idea of what it would be worth when and if I decide to sell it? I plan on someday doing the swap just not now. I won't be driving it much except for the occasional sunday drive.
Thanks,
Justin
71 K5, AC/Tilt, 4" lift 33" tires
5.3L/4L60E/NP 205 (Under Construction)
05 Dodge 2500 4x4 5.9 Cummins (Daily driver)
"Common sense is not so common"
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=555879
Jdubs71 is offline   Reply With Quote
Old 01-24-2013, 08:17 AM   #2
Indian113
Indian113's Avatar
Re: 04 5.3L What is it worth
I bought the same setup for my S10 from a Yard only with 80,000 miles on it for $850.00. With the lower miles yours should be worth more!
Indian113 is offline   Reply With Quote
Old 01-24-2013, 09:23 AM   #3
66C06
66C06's Avatar
$1000 max for the motor, harness, ecu and dbw setup. If you had an 4l60 to go with it you would probably get 15-1600 out of it. Let me know if you are interested in selling it, I buy them all the time, refresh them and put them in old stuff. I have a 55 belair that's getting a 5.3, big cam, ls6 heads and intake...looking at about 370rwhp/tq
66 SWB Stepside: Project C-O6
06 ZO6 MSM 6spd 562/520rw N/A
06 Caddy CTS The Daily
07 Hayabusa - absolute chaos
66C06 is offline   Reply With Quote
Old 01-25-2013, 03:15 AM   #4
softballnrd27
Always a work in progress
softballnrd27's Avatar
What is the big price difference? I would keep the 5.3 and swap it in. Mounts are cheap, modding your own harness is cheap and easy to do just time consuming. You can use your current trans and you can buy the flat flexplate and spacer for cheap. If you want to make it even easier to swap you can replace the DBW with a DBC throttle body and go that route. The most expensive, but can be done for fairly cheap, is the fuel system. That is just my take on it. Even the stock 5.3 will have way more power than a freshened up stock 350 and get close to 20mpg.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 02-01-2013, 04:32 PM   #5
Sonoma10714
Thanks,
Justin
I would def be interested if you plan on selling.
Sonoma10714 is offline   Reply With Quote
Old 02-01-2013, 04:53 PM   #6
Jdubs71
Jdubs71's Avatar
I will keep that in mind. I've been pricing things out and I may be about even either way I go. I'm leaning more towards doing the swap. I won't be happy later if i dont.
My build thread
Old 02-01-2013, 05:07 PM   #7
mooseknuckles
mooseknuckles's Avatar
just a word of caution....when doin an ls swap, your sunday driver, will eventually turn into a daily driver....
mooseknuckles is offline   Reply With Quote
Old 02-01-2013, 06:18 PM   #8
Jdubs71
Jdubs71's Avatar
Im honestly okay with that. No point in having a restored blazer rotting away in the garage. It will make long trips much better.
My build thread
