Old 01-24-2013, 12:20 AM   #1
RdoubleU
RdoubleU's Avatar
Captainfab D52 Rear Disk Brake Brackets + Calipers
This is almost a full rear disk brake setup for a 12 bolt Rear
Just need the Astro Van rotors
  • Captainfab D52 Rear Disk Brake Brackets (painted not powdercoat)
    New unopened loaded D52 calipers with pads and hardware from CPP
    New rubber hoses with banjo bolts for D52
    All kit hardware included (only missing the 8 bolts that connect the bracket to the axle flange)
Details about the kit can be found here: http://www.67-72chevytrucks.com/vboa...d.php?t=398352
The bracket Kit was only used for mock-up and the calipers are unopened
Asking $325 + Shipping
RdoubleU is offline   Reply With Quote
Old 01-26-2013, 02:04 AM   #2
RdoubleU
RdoubleU's Avatar
Re: Captainfab D52 Rear Disk Brake Brackets + Calipers
Bump
Old 01-26-2013, 07:36 PM   #3
WIDESIDE72
WIDESIDE72's Avatar
Does this set up include an e brake provision?
WIDESIDE72 is offline   Reply With Quote
Old 01-26-2013, 08:35 PM   #4
RdoubleU
RdoubleU's Avatar
These calipers do not have the ebrake provision, they are the standard front D52 style
The ebrake style calipers were used for the rear calipers for the '76-'78 Cadillac Eldorado
These brackets will work with both style calipers and use the same rotor so in summary you'd have to buy the Cadillac calipers to have a ebrake
Old 01-27-2013, 01:14 AM   #5
Jdubs71
Jdubs71's Avatar
Pm sent
71 K5, AC/Tilt, 4" lift 33" tires
5.3L/4L60E/NP 205 (Under Construction)
05 Dodge 2500 4x4 5.9 Cummins (Daily driver)
"Common sense is not so common"
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=555879
Jdubs71 is offline   Reply With Quote
Old 01-28-2013, 06:55 PM   #6
RdoubleU
RdoubleU's Avatar
bump - still for sale
Old 02-01-2013, 10:23 PM   #7
RdoubleU
RdoubleU's Avatar
Bump
Old 02-14-2013, 12:43 AM   #8
RdoubleU
RdoubleU's Avatar
bump
Old 03-01-2013, 12:07 AM   #9
RdoubleU
RdoubleU's Avatar
ttt
Old 03-01-2013, 01:05 AM   #10
HotRod C/10
HotRod C/10's Avatar
how much with out the calipers? I have the caddy ones with e-brake already
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 03-02-2013, 11:26 AM   #11
RdoubleU
RdoubleU's Avatar
I'll do 200 on just the brackets
would like to get rid of the calipers as well so someone can use them - let me know any offers
Old 08-20-2016, 12:06 AM   #12
hardwaycooke
hardwaycooke's Avatar
ever sell these??
71 LWB
Large Bore 6-71 Blown 383 Stroker
4.11 Motive/EOM Eaton Posi Ported/Polished Carrier
15x8/15x16.5 MT Radials
B&M Pro Shifter
Truck Name- Spike
hardwaycooke is offline   Reply With Quote
Old 01-16-2020, 01:19 AM   #13
gijoecarlos
sell them?
gijoecarlos is offline   Reply With Quote
Old 01-16-2020, 02:38 AM   #14
kingNothing
kingNothing's Avatar
Where in Alabama are you located?
Yeah' well sometimes nothin' can be a real cool hand
Lucas Jackson
kingNothing is offline   Reply With Quote
