Old 01-24-2013, 12:56 AM   #1
rotorhd58
s465 muncie
changing seals and gaskets on 1970 C10 4 speed 465 it has been sitting for about 25 yrs went to pull off top cover with stick shift still attached, it comes up about an inch then seems like one of the forks gets stuck is there a certain way to get the forks loose ?
rotorhd58 is offline   Reply With Quote
Old 01-24-2013, 01:00 AM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: s465 muncie
What gear did you have it in? I always put it in neutral and remove the shift lever first.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 01-24-2013, 01:40 AM   #3
dan42
dan42's Avatar
Re: s465 muncie
You don't have to take the top cover off to take the shifter out. You press down on the round seal on the bottom, and turn it, and the shifter comes right out. But it still needs to be in neutral.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 01-24-2013, 04:46 PM   #4
burnin oil
Re: s465 muncie
Use the shifter to engauge the reverse gear half way then the top cover should pop right off. To remove the shifter just use a screw driver and a hammer. Stick it in the stamped cover at a corner and tap down at a 45* angle counter clockwise. Should pop right out.
burnin oil is offline   Reply With Quote
