Old 01-24-2013, 12:14 PM   #1
Transformula
Transformula's Avatar
Header difference question
I've noticed 2 main header design differences and I wonder if it's just different brand designs or fitment. I have seen the same on either 2wd or 4wd, both 67-72 and 73-87. So I believe it to be brand related. The first design has the front exhaust tubes run immediately down, right behind the motor mounts and center two tubes. The second design has the front exhaust tubes run a bit up, then over the center two exhaust ports before finally turning down toward the rear.
T.Y.N Custom Works..... Because "Stock" Sucks!
1971 K 10 GMC Long Bed
1977 Formula T/A Frame off Resto-Mod
1995 FXDL Harley Low Rider
1985 C10 ShortWide 91 Burb front.
Transformula is offline   Reply With Quote
