Old 01-24-2013, 12:33 PM   #1
RustySpoke
RustySpoke's Avatar
Differential questions
I have a 1965 chevy 10 and I found a rear end out of a 1970 chevy 10
1. Will it bolt in as a direct replacement?
2. Is it wider or narrower than a 1965
3. I think it is a 5x5 but haven't asked the guy??
Thanks for all the help guys
Greg
" REAL MEN LOVE JESUS "
1965 chevy Short B STEP/S blown apart
1965 chevy SHORT B Fleet 230 3sp D/D
1966 chevy LBFS 4 cell
1977 MGB rag top 4 cell
RustySpoke is offline   Reply With Quote
Old 01-24-2013, 01:30 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Differential questions
1) yes, if its coil rear. If not you will need to weld on new saddles. 2)Maybe. Break out some measuring. Tools. My rear was a little wider. My 1962 trailing arms are wider than the ladder frames. Had to weld saddle on out side the ones on my 12-bolt.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 01-24-2013, 03:52 PM   #3
Bret B
If I recall, there is a small difference from the 68 and newer rear ends compared to the '67 and older. I pulled a rear from a 1971 C10 and Suburban with the intent of putting one of them in my '65. As stated, if it is coil spring, its a bolt in, no problem. If it is leaf spring, I don't know for sure. Come to find out, the 1971 truck and burb are about 1~1-1/2 inches wider on each side than the '65 rear.
You could get a 5x5 bolt pattern rear on the 1971 suburban, and I think it was 1972 for the C10, hope someone can confirm that. The Impala SS of era 1996'ish had 5x5 bolt pattern to. Then there is Ford 9" and for that you'd have to do some searching in this forum for that information.
1965 Chevy short-step side, work in progress....
............................____
..................______l/___\____
.................|_/(0)\_ll____/(0)_l.
Bret B is offline   Reply With Quote
Old 01-25-2013, 03:14 AM   #4
Captainfab
60-66 Nut
The 1970 12 bolt coule be either 62" wide or 63.5" wide, depending on whether it is a early model or later model '70. Either way it will have 6 lug axles unless someone has changed them. The good news is that it will bolt right in under your '65.
The '71 and up C10 truck 12 and 10 bolts were all 5x5 wheel bolt pattern and are 1.5" wider than the earlier differentials. Most of the '72 and earlier under Chevy's were for trailing arms, but most all '63-'72 GMC's had leaf springs.
Old 01-25-2013, 10:16 AM   #5
RustySpoke
RustySpoke's Avatar
Thanks captainfab, my 1965 c10 230 three on the tree has a 4:10 under it and I use it as my daily driver but don't get to drive it on the interstate due to the RPM's that it turns. I found this 1970 3:08 at a good price, so before I pulled the trigger on it I wanted to know if it would fit. Thanks everyone!
Hey Captain why don't you make some early 6 cyl P/S brackets? Man talking about scarcer than hens teeth, I have been looking for a year for the OE brackets.
Greg
Old 01-26-2013, 01:26 AM   #6
Captainfab
60-66 Nut
Because someone else is already making them.....
http://www.ebay.com/itm/194-215-230-...a286e7&vxp=mtr
http://www.ebay.com/itm/194-215-230-...93ad10&vxp=mtr
There are currently some OEM ones on ebay also.
Greg
Old 01-26-2013, 08:27 PM   #7
RustySpoke
RustySpoke's Avatar
thanks captain, I haven't been on ebay for awhile.
Old 01-26-2013, 08:41 PM   #8
hop sing
hop sing's Avatar
SORRY 2 JUMP IN ON THIS ONE I HAVE 61 THE REAR END LOOKS LIKE 9IN STLYE BUT HAS STUDS HOLDING IN FRONT AND BACK OF THE PUMPKIN ANYONE HAVE ONE ? AND WHAT GEAR SET IS IN THEM RIGHT NOW WITH A 350/AND 700R4 I AM TURNING 2500 RPM'S AT 70MPH ,,FEELS LIKE 4,11 OR 3,90 THX GUYS WOULD LIKE TO GET A POSI IN THERE ANYONE GOT ONE ? MAHALO HOP
hop sing is offline   Reply With Quote
Old 01-27-2013, 12:04 AM   #9
Trsmotrhed
Trsmotrhed's Avatar
Greg
I have a 12 bolt from a 72 with 5X5 lug 3.08 gears I'm taking out of my truck for a ford 9" with disk brakes. I have this 72 under my 63 right now and bolted right in.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline   Reply With Quote
Old 01-27-2013, 01:37 AM   #10
Captainfab
60-66 Nut
If your '61 is a C10, then you have the Eaton HO32. More than likely you have the 3.90 gears that about 90% of them came with. There are no new aftermarket posi's made for these differentials that I know of. You will have to find a good original. These differentials were used from 2nd series '55 thru '62.
Old 01-27-2013, 04:42 PM   #11
hop sing
hop sing's Avatar
thx captain u r a wealth of info ,,if u know of any posi units out there ho32 any gear can u let me know?got a fresh 12bolt posi unit for a car 12bolt would trade for it or the old $$$$ too
Old 01-27-2013, 07:29 PM   #12
Bret B
Not sure if all the questions have been answered for this thread yet, but I remembered I asked some of the measurement questions sometime ago, and here is the linky: http://67-72chevytrucks.com/vboard/s...d.php?t=441037
Hope it helps.
Old 01-27-2013, 09:44 PM   #13
RustySpoke
RustySpoke's Avatar
Hope it helps.
Thanks Bret B........so did you change you wheels to a different offset or what?
Hey Captain Fab do you know if the ring and pinion and carrier will fit out of an 1970 diff in to my housing?
greg
Old 01-28-2013, 02:13 AM   #14
Captainfab
60-66 Nut
All truck 12 bolt parts are interchangeable. Have you checked to see if that '70 differential is the wide or narrow one? If it is the narrow one, why not just change the whole thing?
greg
Old 01-28-2013, 09:21 AM   #15
RustySpoke
RustySpoke's Avatar
Thanks Captain.....I haven't called the guy yet as I didn't want to waste his time until I found out that it will work. I will call him and see if he will measure it for me.
Thanks everyone!
Greg
Old 01-28-2013, 12:51 PM   #16
Bret B
Rustyspoke, the rear I have now will not allow the ralley wheels to fit, I'm sure you read that in my other thread. If I go with a backspace of 5 inches and 3 inches in the front, wheels will fit nicely and allow for a decent tire as well. However, the comparison from front to rear look will be awkward. Meaning it'll look like a front wheel drive setup, deep dish in front, thin lip in the rear. Unless I use the same wheel up front of course.
At this point, I'm going to a 9 inch rear end. I have a 9inch housing and pumpkin to rebuild already. Have no idea what it is out of and there were no brake components on it. Gear ratio is 2.75, non-posie, 28 spline axles. Not having the brakes isn't an issue, I'm leaning toward rear disks anyway. There are threads of swapping a 9inch in so that is where my research will be directed soon.
Old 01-28-2013, 04:55 PM   #17
gbrown
gbrown's Avatar
Captainfab, I've noticed you seem to have a lot of the answers here; would you bear another question you've likely answered before... for a new guy?
I've got a 1960 Chevy C10 with a bad rear-end. I'm on a major budget and was wondering if you could provide some insight as to what rear-ends are a direct replacement for mine? (I'm operating under the assumption that I can find a usable one in the salvage yard for less than I can have mine rebuilt) Any info you can provide would be great, thank you.
gbrown is offline   Reply With Quote
Old 01-28-2013, 05:14 PM   #18
Bret B
gbrown, I don't know which models would be a direct bolt in for your truck. Off the top of my head, I'd assume '60-'62/'63, but I'm not sure. Regarding your comment about rebuilding being more than another rear, this truly depends on what is wrong with your rear to begin with. If it is simply the seals and bearings, you're better off replacing those and moving on. If it has something to do with the a posi-unit or gear set, it would boil down to hoping the new unit is better than the one you're removing. Some of the cost can certainly be mitigated by you doing the work yourself and finding friends who have done rebuilds as well.
Old 01-28-2013, 09:24 PM   #19
RustySpoke
RustySpoke's Avatar
Well I got the guy to measure and it is the wide rear end, I will have to decide weither to buy it and take the ring gear and pinion and carrier out and use them or keep looking.
Hey Captain did we confirm that a 1967--early 1970 with 6 lug axles is the correct one? Oh and do you know if the v8 auto's had a tall gear?
thanks
greg
Old 01-28-2013, 10:28 PM   #20
gbrown
gbrown's Avatar
Ok, things are getting weird... my VIN says I've got a C10, but according to the pics of the rear diff and my LMC catalog, I'm thinking I've got a 3/4 ton rear. Can anyone help me ID it? Unfortunately, the truck is at my dad's house so I'm doing the best I can with pics, see below:
(Yes that's a cardboard gasket and, yes, it was dry when I took the cover off)
Old 01-28-2013, 10:55 PM   #21
RustySpoke
RustySpoke's Avatar
yeah it looks like a c20 does it have floating axles?
Old 01-28-2013, 10:57 PM   #22
gbrown
gbrown's Avatar
I don't know. I'll have to research what that means and get back to you. Like I said, the truck is at my dad's house 45 minutes away. Maybe this weekend...
Old 01-28-2013, 11:04 PM   #23
RustySpoke
RustySpoke's Avatar
if you can remove the axles without taking the wheel off, its a c20
Old 01-29-2013, 02:41 AM   #24
Captainfab
60-66 Nut
Your C10 has the Eaton HO32 differential that was used from second series '55 thru '62 in the 1/2 tons. Those do look basically the same as the Eaton HO52/72 used in the C20's up thru '72.
If it is just the center section that is bad in your differential, you could try and find another good 3rd member and just change it, That would be the easiest and cheapest to get you back on the road. Alhtough you'll likely still be stuck with 3.90 gears, which aren't very highway friendly.
The next step would be a '63-'64 12 bolt. Those will have the same panhard bar mount, but the trailing arm mounts are a little closer together. It is possible that threr is enough movement ion your trailing arms, to get them to bolt up. Otherwise, the trailing arm mounts will need to be cut off and welded back on at the correct distance and pinion angle.
Then there is the '65 to early '70 12 bolts. The same situation with the trailing arm mounts. But these differentials use a shorter panhard bar. They can be used, but the panhard bar will need a slight bend in one end to be able to bolt it up to the frame bracket.
Old 01-29-2013, 02:49 AM   #25
Captainfab
60-66 Nut
The '65 to early '70 12 bolts are exactly the same, as in a direct swap. The '63-'64 12 bolt will bolt up except they are setup for the long panhard bar. The long panhard bar can work with a slight bend in the frame end.
If you are just talking about the internal parts, all truck 12 bolt parts from '63-'82 will interchange. The one thing that is different is in the '63 and '64 12 bolts, they used 17 spline axles and spider gears. '64 and up used 30 spline.
The auto trans trucks could have 3.73's, 3.42's or 3.07's. Some of the later models came with 2.73's.
thanks
greg
