Old 01-24-2013, 02:11 PM   #1
ZEEGERMN
ZEEGERMN's Avatar
hello from AZ.
hi my name is marcel,....this is my first truck its a 61 chevy 1/2 apache..of a guy of C.L for $1300..running but not safe to go on freeway or stuff. but after new master,brakelines,all the wiring..new intake and all the gasket's for the 77 350....if got her TDC..and timed ....had to readjust the weber 4 barrel(gas.air mix) and the idle addjustet. i put a new ragjoint in...and thinking about power steering and dics...BUT..like so many of us...i m on a budget......and broke !!!! well,i know, i need to do the front and rear bearings..and wheel cylinders ...and ,and ,and.....but thats what i love about this hobby or passion if you like....you can always just go out to the shop,garage or covert parking space.. and get away from everything .
and in my case,i lived in germany allmost all my life...and the classic car thing was not really my thing.but when i moved to the US that all changed. 10 jeahrs ago i didnt know how to do my own oil change ... and by now i have build 4 cars i bike and now a truck. i got infected thanx to my co worker mike. i just now became a member,never had a truck. i wanna thank all of you for all that information you put out ...helps me every day!!!
thanx
ZEEGERMN is offline   Reply With Quote
Old 01-24-2013, 02:22 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: hello from AZ.
Welcome to the forums.
Glad to have you.
I agree, great hobby.
66 C20 Service Truck:
Old 01-24-2013, 02:39 PM   #3
TehNewGuy
TehNewGuy's Avatar
Re: hello from AZ.
Welcome from Sunny Miami, FL! sounds like you got a good grasp on your truck already and by the pictures, it looks pretty nice. By the way, if I can say so, the forum name you chose is great!!!
1966 Chevy C10 LWB Fleet- Project
TehNewGuy is offline   Reply With Quote
Old 01-24-2013, 03:00 PM   #4
ZEEGERMN
ZEEGERMN's Avatar
Re: hello from AZ.
Size:  43.5 KB i did all the rust repair to doors and fender...working on hood right now...just crankt out the T-Bars...and cut a coil out of the rear!!!
Old 01-24-2013, 03:01 PM   #5
Johnny Bones
Re: hello from AZ.
Welcome to the forum!! I am out here in Glendale Az. Hit me up if you need help with your truck or just want to go cruisin!
Johnny Bones is offline   Reply With Quote
Old 01-24-2013, 03:03 PM   #6
TehNewGuy
TehNewGuy's Avatar
Re: hello from AZ.
Doors look good once they are down to clean metal haha. Whoa see this is what i was talking about in another thread... You cut the rear coil spring? how did you mount it back on to the frame? anychance you have a picture of it?
Old 01-24-2013, 03:04 PM   #7
ZEEGERMN
ZEEGERMN's Avatar
Re: hello from AZ.
hey johnny bones..thanx!!.i will!!!
Old 01-24-2013, 03:08 PM   #8
ZEEGERMN
ZEEGERMN's Avatar
Re: hello from AZ.
i think i cut out to mutch its on the bumpstop...but ill get some jeep springs this weekend....and my t-bars still can go out more...i got about an inch left...but..those sucker are rusted and i dont wanna brake that bolt...so I'm soaking them right now...ill post some pic's later..
Old 01-24-2013, 03:11 PM   #9
ZEEGERMN
ZEEGERMN's Avatar
Re: hello from AZ.
ijust jused sone plate i had ,drilled a hole and bolted that back
Old 01-24-2013, 03:13 PM   #10
hopped up
hopped up's Avatar
Re: hello from AZ.
I wouldnt use the jeep springs. Theyre worthless if you wanna carry anything in the bed. I cut my rear springs and it rights soo much nier than when i had the jeep springs. You have alot of guys from az on here. Im sure youll get to know them
hopped up is offline   Reply With Quote
Old 01-24-2013, 03:18 PM   #11
ZEEGERMN
ZEEGERMN's Avatar
Re: hello from AZ.
thanx "hopped up" nak muay ??
Old 01-24-2013, 03:24 PM   #12
ZEEGERMN
ZEEGERMN's Avatar
Re: hello from AZ.
Size:  63.5 KB 1977 ,350.
Old 01-25-2013, 03:06 AM   #13
Captainfab
60-66 Nut
Re: hello from AZ.
Welcome to the forum Marcel
You've been doing some nice work
Old 01-25-2013, 07:39 AM   #14
MikeS.
MikeS.'s Avatar
Re: hello from AZ.
Willkömmen Marcel.
In the engine pic with the manifold off, is the middle port plugged? It's hard for me to tell from the angle. If it is you should remove the manifold and clean them out.
That port supplies hot exhaust gas to the fuel/air mix from the carb. Helps keep the fuel a vapor.
On my 283 both ports were clogged. It wasn't hard to clean out while I changed manifold and carb.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 01-25-2013, 08:31 AM   #15
chakah
chakah's Avatar
Re: hello from AZ.
Cool truck Zee, welcome. Nice work on the doors
"El Jerry"
'03 3500 Duramax dually
'96 1500 ext. cab Chevy
'66 swb C-10
'63 Panel
'60 VW vert
'56 VW vert
chakah is offline   Reply With Quote
Old 01-25-2013, 09:06 AM   #16
glos55
glos55's Avatar
Re: hello from AZ.
Welcome from Michigan! Truck is looking Good!!!
LIFE IS SHORT HAVE FUN
glos55 is offline   Reply With Quote
