Old 01-24-2013, 03:24 PM   #1
68c10owner
68c10owner's Avatar
tire question
I finally picked up some decent wheels for my 83 C10 but 2 of them need tires. currently they have 275/60/15 on 15x8 eagal wheels. Im planning to do a 3/5 drop in the near future and wondering if i should step down to a 255/60/15 for the front for a little extra clearance but also to help the ride height a bit. Any thoughts? Currently has stockers with 225/75/15.
Anthony
68c10owner is offline   Reply With Quote
Old 01-24-2013, 03:57 PM   #2
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: tire question
A 245/60 is perfect for the front
Malo83 is offline   Reply With Quote
Old 01-24-2013, 04:36 PM   #3
68c10owner
68c10owner's Avatar
Re: tire question
Ive seen that run up front as well. You dont think it`ll look too small compared to the rear 275/60`s? Not going to be able to lower it right away either so dont want it looking goofy untill I can do it.
Anthony
Old 01-25-2013, 04:34 AM   #4
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: tire question
You tell me?
Uploaded with ImageShack.us
Old 01-25-2013, 04:44 AM   #5
cory d
cory d's Avatar
Re: tire question
if i done go 17" with my next wheels/tires then im goin to do 255/60/15 and 275/60/15 27" and 28". right now i have 255/70's 29" and they looked good at 3/5 but not that im a bit lower they fill the front wheel welll too much
cory d is offline   Reply With Quote
Old 01-25-2013, 10:46 AM   #6
68c10owner
68c10owner's Avatar
Re: tire question
You tell me?
are you running a 245/60/15-275/60/15 combo? I thought you always ran the 50 series tores on your truck.
Anthony
Old 01-25-2013, 04:02 PM   #7
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: tire question
This pic is all 245/60/15's, I did have 275/50/15's but BFG quit making them, the 245's are the same diameter but not as wide as the 275's
Old 01-25-2013, 04:16 PM   #8
68c10owner
68c10owner's Avatar
Re: tire question
your truck still looks awsome but my problem is Im going to have 275/60/15 on the rear and Im thinking 245/60/15 up front might look funny at stock height. Not going to be able to lower it right away but hopefully soon. Thats why I was thinking 255/60/15 up front. Future plans are installing the rear flip kit I got from the guy in the classified section and get some shock extenders. Then buy a set of 3" drop spindles and maybe cut half a coil front the stock spring. I want the nose just a little lower than the rear.
Anthony
Old 01-25-2013, 04:39 PM   #9
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: tire question
Check out this site, it will give you an idea of the size differences
http://www.tacomaworld.com/forum/tirecalc.php
Old 01-25-2013, 04:44 PM   #10
68c10owner
68c10owner's Avatar
Re: tire question
Thanks. Im familiar with the different tire diameters. That isnt the problem. My 275/60`s are 28", 255/60`s are 27" and 245/60`s are 26.5" depending on manufacturer specs. My thoughts are the smaller 245/60/15 might not look right with so much air between the fender and the tire compared to the 275/60/15. Dont really know how to explain this other than picture a stock height truck with stock 225/75/15 on the front and 31x10.5x15 on the rear. They both fit but the bigger rear tires make the smaller fronts look really small. Now if the truck was lowered the difference wouldnt be so noticable. My problem is the truck wont be lowered for several months and Im buying tires in the next week or so.
Anthony
Old 01-25-2013, 05:06 PM   #11
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: tire question
Drop the truck first, then deal with tires, it will save you a lot of headaches down the road, depending on how low you go your gonna need a smaller tire, a 275/60 on the back will not be a problem, but the front, need to avoid tire rub
Old 01-25-2013, 05:22 PM   #12
68c10owner
68c10owner's Avatar
Re: tire question
easier said than done. I dont have room to store these wheels for months and months so they are going on asap. Guess Im sticking with 275/60`s.
Anthony
Old 01-25-2013, 05:29 PM   #13
J Knight
J Knight's Avatar
Re: tire question
Get the tires that look good AFTER you drop it, it wont matter what they look like now if its not staying that way.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 01-30-2013, 04:49 PM   #14
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: tire question
It'll be fine with 275s. I run 275/60/15 on all four corners with a 4/4 drop and nothing rubs.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
