Old 01-24-2013, 03:34 PM   #1
71long
Original paint scheme
How can I tell if this is the original paint scheme of my truck? I think it has been repainted and I'm not sure if this how it looked from the factory.
71long is offline   Reply With Quote
Old 01-24-2013, 04:04 PM   #2
71K20chevy
71K20chevy's Avatar
Re: Original paint scheme
What does the SPID list on the glovebox door?
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 01-24-2013, 04:04 PM   #3
Graham57a
Graham57a's Avatar
Can you post a pic of the SPID on the glovebox door? It should have the paint scheme code on it. Beautiful truck by the way
ANDREW
1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072
1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827
1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315
1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788
1972 Chevy SWB Highlander OLIVE Build thread coming
Graham57a is offline   Reply With Quote
Old 01-24-2013, 05:13 PM   #4
RenoKeene
Florida Edition
RenoKeene's Avatar
Welcome from Florida! Real nice looking truck. Like they said, check the spid for the paint code.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 01-24-2013, 05:17 PM   #5
71long
Here it is.
Old 01-24-2013, 05:28 PM   #6
71K20chevy
71K20chevy's Avatar
That's correct then. Really nice truck
71 K20
64 GMC mud truck
Old 01-24-2013, 05:34 PM   #7
Graham57a
Graham57a's Avatar
Wouldn't it say White/Ochre/White since below the lower molding is white? I could be wrong but that was my understanding. It could be that someone added the white under the lower trim when they repainted a few years ago.
ANDREW
Old 01-24-2013, 05:53 PM   #8
71K20chevy
71K20chevy's Avatar
Never thought of that, that's a possibility too.
71 K20
64 GMC mud truck
Old 01-24-2013, 06:40 PM   #9
SS Tim
SS Tim's Avatar
The truck is a conventional Two-Tone per the paint code 536 which is a reliable indicator vs the plant erratic descriptions. So as it correctly states it was built white over ochre. If the white lower paint were factory the code would be 590.
The VIN decodes as:
C - Conventional Cab 4x2
E - V-8 engine
1 - 1/2 ton
34 - Wideside bed
- - Blank
1 - Oshawa assembly plant
1 - 1971
249XX - Serial number
Also if any you are following my RPO D99 posts, this is a clear example of the Canadian exception actually posting the code on the SPID. US built trucks generally only show the code on the build sheet.
SS Tim is offline   Reply With Quote
Old 01-24-2013, 06:50 PM   #10
71long
So should it have the upper mouldings as well? What exactly does D99 mean.
Old 01-24-2013, 08:16 PM   #11
Graham57a
Graham57a's Avatar
D99 designates two tone. I believe the upper molding is correct
ANDREW
Old 01-24-2013, 09:18 PM   #12
SS Tim
SS Tim's Avatar
The truck is a Z84 trim on the SPID called the earlier (70 down) Custom Sport Truck. It is the same code for Cheyenne or Sierra trims as this truck is.
The lower body side molding option is included with Z84.
The upper trim is not part of Z84.
If this truck had been built with the upper belt molding it would be on the SPID as RPO B85.
So your truck as indicated on the SPID, will have a white roof, D99 divider trim along the back of the cab, Ochre body paint and lower body side moldings.
Not wanting to again go too far into this, the RPO D99 code is for the two-tone cab roof paint divider molding. It normally is not seen on SPIDs in the US (nor needed for service) but is on Canadian SPIDs. Normally it will only be seen on build sheets and basically notes the build needs the divider molding clip studs welded to the cab.
Old 01-24-2013, 10:06 PM   #13
71long
Thanks for the info.
