01-24-2013, 04:42 PM | #1 |
Fan Motor ?
Can you remove the fan motor without removing hood hinge ? Non A/C Cab.
71 C-20 07 Magnum RT AWD |
01-24-2013, 05:05 PM | #2 |
Re: Fan Motor ?
I think you can but you have to move the hinge forward. Someone please correct me if I'm wrong.
71 K20 64 GMC mud truck |
01-24-2013, 05:14 PM | #3 |
Re: Fan Motor ?
Thanks, I have a good spare but it's cold and I don't want to screw around with the hood right now! It looks like you could squeeze it out around the hinge ?
01-24-2013, 05:30 PM | #4 |
Re: Fan Motor ?
Yup, you oughta be able to squeeze it out.
Have fun! NOT
01-24-2013, 06:16 PM | #5 |
Project Junkie! Fishing Poor!!
Re: Fan Motor ?
I haven't had any luck doing that. I always wind up removing the hinge. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
01-24-2013, 06:48 PM | #6 |
Active Member
Re: Fan Motor ?
Use a pencil to outline around the hood hinge bracket if you have to remove it. I've had good luck reinstalling it by doing that.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
01-24-2013, 10:19 PM | #7 |
Re: Fan Motor ?
Thanks guys, I got all the little 5/16 screws out after playing Houdini for about an hour in the cold, and guess wat ? You CAN NOT get the fan motor and squirrel cage out of the housing with out unbolting the hood hinge !
01-24-2013, 10:33 PM | #8 |
Re: Fan Motor ?
My apologies for wasting your time
But at least Oregon isn't as cold as Indiana!
01-24-2013, 10:57 PM | #9 | |
Active Member
Re: Fan Motor ?
Temp here in my area of Texas was in the mid 70's. Had to turn the a/c on in the house.
01-25-2013, 12:04 AM | #10 |
Re: Fan Motor ?
You can drop the inner fender down and get it out too. Don't have to touch the hinge that way.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
01-25-2013, 12:49 AM | #11 |
Re: Fan Motor ?
I just did this a few weeks ago. Search my old posts. It isn't that hard, but yeah- you need to remove the bottom screws from the hinge. Having removed my inner fender before, I think the hinge I easier.
Posted via Mobile Device |
01-25-2013, 12:49 PM | #12 |
Re: Fan Motor ?
I think I will try to drop inner fender, my helper "wife" hurt her arm so removing the hinge is out of question right now
01-25-2013, 12:57 PM | #13 |
Re: Fan Motor ?
Would it be easy to remove the whole box assembly under the hood and have the blower motor slide out with it? You would prob have to pull the blower motor out a little so the cage doesn't get caught on the cab. When I removed my blower motor I never had to remove anything... I wonder if my blower was an aftermarket could possibly be a smaller? Who knows.
01-25-2013, 01:39 PM | #14 | |
Re: Fan Motor ?
01-25-2013, 01:40 PM | #15 |
Re: Fan Motor ?
The fan is mounted to the heater core assembly on the engine side of the firewall, interior assembly is the air distribution part of the system. I am going to remove the entire engine side housing to check for debris like leaves and stuff and also replace the stock heater core while I have it all apart. Would also like to replace the aftermarket heater hoses and cheep POS clamps that are on it now! Does anyone know where to get GM script hoses and original type tower clamps ?......Thanks for the input guys
