Old 01-25-2013, 04:40 AM   #1
moggey01
fleetside vs stepside question
Which bed option will accept the biggest tire?? I want to run up to a 15 or 16 wide tire , and found a deal on a stepside bed. I dont know how big of a tire will fit with this bed.
moggey01 is offline   Reply With Quote
Old 01-25-2013, 05:04 AM   #2
70c10stepside
Re: fleetside vs stepside question
Idk about fleet side, but my 70 has 295s. Its really close. Maybe, another itch, 2 would be pushing it. Not sure on offset of wheels
70c10stepside is offline   Reply With Quote
Old 01-25-2013, 10:11 AM   #3
CC69Rat
CC69Rat's Avatar
I have both trucks. One fleetside, one stepside. No question about it, with stock unmodified wheel tubs the fleetside gives you more room for tires.
The key here is knowing which rear end housing your truck has in it. The earlier rear housings were 55.5" long if you measure from the inside edge of one brake backing plate to the other. The later ones were 57" respectively. I guess you can see where it might be a deal breaker if someone has the early rear end and tells you "x backspacing" will work .. then on yours if you have the longer one it's now off .75" on each side.
But, for the most part.
Fleetside bed:
Early rear end housing. 20x10 with 5" Backspacing
Late rear end housing. 20x10 with 5.5" Backspacing.
If your truck is really low, you might want to go a little deeper (more BS) but most guys running about 6" drop in the rear run this size wheel with a 295/40/20 in the back. I personally went with a 295/45/20 for a little more sidewall.
Example - my fleetside = late rear housing and a 20x10 with 6" BS. I did this because of the added tire size, plus my rear discs.
On my stepside I had 20x8.5 with 4.75" BS and an early rear housing. It was really tight with a 255/45/20.
If you want Big meats .. go fleetside.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 01-25-2013, 01:59 PM   #4
moggey01
my housing is going to be cut to fit the wheels , it has no ends now. The ride height should be about 5.5 inches at the frame maybe a little higher on the rear. I am using big aluminum tubs no matter what I do , I want to use a 14'' wide wheel or atleast a 12''. Thanks for the info I did not know the width of the early housing and was trying to figure that out. I have a chromoly fabbed housing that is 60'' with no ends. I need to find out how close the frame is to the inside of the fender on the step side.
