one piece rear glass
Is swapping my crappy rear slider for one piece glass as simple as removing the slider and installing the single glass?
RIZ |
Re: one piece rear glass
Yes, you can interchange them. I actually wanted the reverse and took the fixed glass one out and replaced with a slider. Just do it on a warm day so the rubber is soft. I used glass cleaner as a soapy lubricant and seemed to work well.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires ![]() 04' GMC Yukon XL, 3/4 ton, 8.1L |
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
Ivory soap works well also, a 50/50 %, mix soap/water in a spray bottle & wet the rubber before install
Is your slider a factory one or and aftermarket one? If its a factory one, you will have to change the gasket. The OE ones are thicker than the aftermarket sliders.
1987 R10 Pump Gas 496/TH375 Best 1/4 pass to date 60' 1.49 1/4 10.93 MPH 120 |
Mine looks like this...
![]() RIZ |
That looks like a factory one like I had. I had just bought a gasket from the dealer I worked at when I had mine. I'm sure other vendors on here have them for the one piece glass.
![]() Join Date: Apr 2009
Im about to get rid of my slider and go one peice on my 78. As i was Looking at glass for sale, the rear glass shows up as two versions, 73-75 and 76-91.
Anyone know what the difference is? I never knew this about these trucks. Posted via Mobile Device |
some dude on craigslist has like 3 new solid back windows. i dont knw his location but they are pretty cheap
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
I am about to do this swap myself. Picked up a solid rear glass and gasket for $30 on Craigslist.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint "Cool ain't ever cheap and cheap ain't ever cool" |
Pick up some glass suction cups from HF , save a headache
Im having a hard time finding a gasket for a aftermarket slider.
1979 ![]() 1996 Silverado x-cab "the daily" |
Are you using a CR Lawrence slider? If so, just use a one piece rear glass gasket.
