Old 01-25-2013, 11:23 AM   #1
Cheeseman
73-87 spindle and axle swap questions
I have purchased a set of drop spindles for my stock 69 C10 and upon purchase I discovered that these are the 73-87 spindles with the disk brakes and 5 on 5 lug conversion. Will these work in conjunction with my stock 69 front cross member/suspension etc or will it all have to be swapped out to a 73-87 assembly? I have read through a lot of the threads but I am not able to get my head wrapped around if I can just swap in different tie rods and ball joints into the 69 assembly and get these spindles to work or if I need to swap in a complete new 73-87 set up. The set up I purchased comes with the brakes etc with it and it is 5x5 pattern, so would my best/most economical route be to just get the 5x5 axle shafts and swap those into my factory 69 housing? Thanks for any assistance.
1969 Chevy C10 "Project Home Wrecker"
"If you think you can't, you are probably right"
Cheeseman is offline   Reply With Quote
Old 01-25-2013, 12:39 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 73-87 spindle and axle swap questions
Read this:
http://67-72chevytrucks.com/vboard/s...68&postcount=4
If you need more help,... I will be glad to answer.
Keith
Convert to disc brakes.
Old 01-25-2013, 12:41 PM   #3
lolife99
lolife99's Avatar
This is the part that applies to you the most,... but read it all.
73-87 Crossmember Not Yet Installed:
1) Your donor 73-87 crossmember came from the factory with disc brakes.
* This swap is almost a direct bolt in, with just a few holes to drill/elongate.
2) The preferred method is to use all of the 73-87 steering linkage:
* This includes the centerlink, inner and outer tie rods, idler arm and steering box. (A great way to gain P/S)
3) If you must use the 67-70 steering components, you will need to change the tie rods:
* The 67-70 inner and outer tie rods are a smaller diameter (5/8") vs. the 73-87 tie rods larger diameter (11/16").
* The 67-70 tie rods are also the opposite thread direction of the 73-87 tie rods.
* 67-70 inner is RH thread vs. 73-87 inner which is LH thread.
* 67-70 outer is LH thread vs. 73-87 outer which is RH thread.
3.1) So to connect the 73-87 spindle to the 67-70 steering centerlink you must use a:
* 67-70 outer tie rod (LH thread) in the inner location.
* connect that to a tie rod "conversion sleeve". (these are sold by many aftermarket suspension companies).
* use a 73-87 outer (RH thread) to connect to your 73-87 spindle.
* Again,... it's much simpler to use all of the 73-87 steering components.
4) Connecting the 73-87 rubber brake lines to the 67-70 steel lines, may require steel line fabrication, or brass "inverted flare" adapters.
5) You can also just swap all the components, from the a-arms out,... and leave your original 67-70 crossmember in place.
* This will require you to completly disassemble both the original 67-70 suspension and the 73-87 donor suspension.
* This is also a good time to clean, inspect, replace or rebuild any needed components.
Keith
Old 01-25-2013, 12:51 PM   #4
Cheeseman
Thanks for the info Keith, it appears it will just be easier in the long run to swap in the 73-87 cross member and not all that big of a job since everything is ready to be torn down. Other than just boring a few holes out and a few new ones it should be an easy weekend job....right? HAHA!
Under #2 it talks of using the steering box from the 73-87 set up. I have PS on my 69 so would my current PS box work just fine with the 73-87 linkages-pitman arm?
Thanks again. I need to make it down that way one of these days
Old 01-25-2013, 01:10 PM   #5
lolife99
lolife99's Avatar
I think your '69 steering box will work fine on the 73-87 centerlink.
Keith
Old 01-25-2013, 01:24 PM   #6
SCOTI
SCOTI's Avatar
Correct.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
