Old 01-25-2013, 12:54 PM   #1
butler57
butler57's Avatar
installing new shocks
I'm replacing my old, worn shocks with KYB - should be a straight forward swap. However, with the new washers the bottom of the rear shock is too wide for the mount. Obviously I want to use the new washers. It would appear that I need to widen the bottom bracket about 3/8" or so.
Any thoughts on how to do this or am I missing something?
Thx
'72 Highlander
'88 GMC Sierra 1500
'14 Chevy Silverado 2500HD Duramax
butler57 is offline   Reply With Quote
Old 01-25-2013, 01:58 PM   #2
Lee H
Lee H's Avatar
Re: installing new shocks
Assuming you have the correct shocks, If the mount is to narrow only use one washer to take up some slack or none.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 01-25-2013, 02:34 PM   #3
butler57
butler57's Avatar
I'm sure the shocks are correct as I did search out the part numbers on the forum. Just wasn't sure what issues I'd cause if I didn't use the washers that came with.
Anyway, thanks for your help.
'72 Highlander
'88 GMC Sierra 1500
Old 01-25-2013, 02:55 PM   #4
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I use washers w/lock washer on the upper connection & washers w/lock washer "outside" the ears on the lower connections. The ears on the lower connection bend very easily and the washers help distribute load and stiffen the ear against the shock bushing...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 01-25-2013, 03:12 PM   #5
ChevyCruizer
17's too small
ChevyCruizer's Avatar
Got a picture?
I think he might be saying that if the washer are put on the inside of the bracket that he will have to spread the bracket.
I personally would not spread the bracket that much, it might make the bolt holes not line up.
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
