01-25-2013, 02:42 PM | #1 |
Rearend code
Trying to decode a 70 12 bolt rearend axle tube is stamped "tph" and then the build date
01-25-2013, 02:53 PM | #2 |
17's too small
Re: Rearend code
I found this.
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows |
01-25-2013, 02:57 PM | #3 |
Re: Rearend code
They must have changed the codes in 71 they are showing tph as a 3/4 ton this truck is a 1/2 ton
01-25-2013, 03:02 PM | #4 |
17's too small
Re: Rearend code
how about this one?
the other thing to do is open the cover and count the teeth and divide. or look for a stamping on the gears and still divide. i used this
01-25-2013, 03:09 PM | #5 |
Re: Rearend code
That looks better thanks for the info
