Old 01-25-2013, 04:39 PM   #1
Skooterr
GMC Dual Wheel Conversion?
I have a 72 GMC Camper Special, orig BB truck. All that was gone 20 yrs ago.
Small block and 4 spd OD now. Been sitting a few yrs but getting ready to start using it again.
I'm interested in going to dual wheels and a flatbed. Any suggestions on the dual wheels.
Current rear with spacers , longer studs, etc.?
New rear from a dually, if so whats the easiest, best?
Which wheels? Any suggestions would be appreciated.
Not interestested in hauling extra weight, just the look, I'll probably fab up my own bed.
Thanks Don
Skooterr is offline   Reply With Quote
Old 01-25-2013, 05:53 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: GMC Dual Wheel Conversion?
I did this a couple of years ago. I had to run 1/2 inch spacers the get the wheels to clear the brake drums. Along with the 1/2 spacer, I had to press in longer wheel lug studs. Other than that, it was a straight forward bolt on.
Old 01-26-2013, 10:42 AM   #3
Skooterr
[QUOTE=Tx Firefighter;5842886]I did this a couple of years ago. I had to run 1/2 inch spacers the get the wheels to clear the brake drums.
Is that why the 1 ton dually rear I seen last week had what looked like a builtin spacer on the drum? I thought it was to get the dual tire/wheel out to clear the springs.
I'm just starting to collect what I need.
Any particular wheels to use, or avoid?
Source on the spacers?
Anyone know the spring perch spread on the 72? 73-87? 89up?
I know where there is an early 80s dually rear, but won't be able to measure mine before my next trip to where the dually rear is.
Don
Old 01-26-2013, 05:12 PM   #4
mrolds88
I'm looking into something similar. I have the same truck (except the big block and the the 400 are still there.) I picked up a pair of mid 70's dually rotors and am looking to put in a D70 dually rear. I know the widths are different between the cab-n-chassis rears and the pick up rears. I also think the spring perches are different too. I know the rear I have from a 69 towtruck I parted the perches are about 1/2" off. I would swap rears anyway, you'll get bigger brakes.
mrolds88 is offline   Reply With Quote
