Old 06-11-2003, 05:10 PM   #1
chevykid1969
chevykid1969's Avatar
Wood Bed
I am replacing the wood in my bed and i have all of the wood out plus the strips. i was just wondering how do you remove the angle strips from the bed. Are they spot welded to the bed side?
Pics soon the come
chevykid1969 is offline   Reply With Quote
Old 06-11-2003, 05:18 PM   #2
1971Stepside
Almost Satisfied
1971Stepside's Avatar
They are spot welded to the bed, but unless they are in bad shape I would leave them. I tried to get the ones off my bedsides and it seemed impossible to do without jacking up the entire bedside. When you order new bedsides they come with the angle strips in place. Good luck and if you come up with a trick let me know.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 06-11-2003, 05:43 PM   #3
gr8scott51
gr8scott51's Avatar
I bought a spot weld cutter (drills thru the center of the weld and cuts a small hole around it) to remove mine. Don't just pry them off, you'll tear the box sides. Of course you have to be a decent welder to attach the new ones. Good luck, Scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
