01-25-2013, 05:21 PM | #1 |
Hazard Switch Stuck on ?
Remember when you where told to "Look But Don't Touch" ! Well I pushed the hazard switch in on my 71 GMC, Good news is it everything works, all lights are blinking ! But when I go to pull the switch back out, It won't budge, Not a bit, WTF is going on ? Pulled the relay to get lights to stop blinking, Anyone had this happen ? I figure it must be the first time the switch was used since Nixon was in the White House...........Thanks Guy's Have a nice Weekend !
71 C-20 07 Magnum RT AWD |
01-25-2013, 05:29 PM | #2 |
Re: Hazard Switch Stuck on ?
yep...me too...the truck had sat for 15 years...everything worked great. Had to use plyers to get it unstuck and broke the switch. Yea! Now i get to tear into the column.
Try some wd40 sprayed in there first...will also help your shifter if it is jancky. I could hardly shift out of park.
70chevytruck |
01-25-2013, 05:57 PM | #3 |
Glad you mentioned that ! My column auto shifter is real hard to move too ? What is proper way to lube the shift linkage ?...thanks have a good one ! Rain today, snow last week
01-25-2013, 11:26 PM | #4 |
mine has a new turn signal switch, and its hard to pull out also....just pull harder and lube it up some...and try not to use it much....good luck.
01-09-2014, 11:25 AM | #5 |
Is there any update on unsticking the hazard light button? Pressed mine today, and the hazards are stuck on. I unscrewed the mounting screw and removed the whole button but that did not fix the problem.
Jim 1972 K20 Cheyenne- 350/350/205 1972 K20 Cheyenne - 350/SM465/205 1971 K5 Blazer |
01-09-2014, 12:51 PM | #6 |
I also have a question concerning the hazard switch, who sells a good replacement. I have two columns and both hazard buttons are broke. I plan on painting the no-shift column this winter and hope to replace the button.
thanks
1970 C10 LWB (Grandfather's Truck) 5.3 4L60E 2012 Victory Cross Country Touring I'm not wasting money on my truck/bike, I'm helping to rescue the economy one mod at a time. |
01-09-2014, 05:49 PM | #7 |
WES or GMC Paul. I would stick with a board vendor that deals daily with our trucks and not just a mail order company that never had a column apart before.
Might try some penetrating oil, sewing machine oil, or even brake cleaner. Most of the column's I have had apart had lithium type grease hard caked on the switch causing them to be stubborn. A squirt of WD 40 after a few minutes freed the switch. After 40+ years you would be stubborn n brittle too.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
