Old 01-25-2013, 06:11 PM   #1
spray it
questions
have a 65 short bed project dropped in a l98 out of 92 camero
i am new to this model truck wooundering if anybody has pics of the heater hose route and were the hoses go from the blower box on the fire wall.
thanks
spray it is offline   Reply With Quote
Old 01-25-2013, 07:36 PM   #2
LVPhotos
LVPhotos's Avatar
Re: questions
intake to firewall, water pump to firewall.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 01-26-2013, 02:04 AM   #3
Captainfab
60-66 Nut
Re: questions
I don't remember for sure, but I think the Camaro may have had the return hose connected to the radiator tank. If so, then there should be a plug in the water pump that you will need to remove, install a hose fitting and connect your return hose there as shown in the pic above.
Old 01-26-2013, 01:46 PM   #4
spray it
Re: questions
yes they came with returns. Also have to run it thru the throttle body. I have the heater core coming thru the fire wall like above but i also have the big blower box on the top left side is that for heat or factory a/c??
Old 01-27-2013, 02:06 AM   #5
Captainfab
60-66 Nut
Re: questions
If you have the heater core nipples coming thru the firewall like in the above pictire, that is for the recirculating heater. With the heater box on the firewall, that is for either the Thrift air heater or the Deluxe heater. These would have the heater core nipples coming thru the top passenger side of the heater box. You should not have both.
Old 01-27-2013, 02:21 AM   #6
TBONE1964
Cluster King
TBONE1964's Avatar
Re: questions
This is my 64. A 65 will be the same with a Thrift heater. The hoses run to the water pump and intake.
TBONE1964 is offline   Reply With Quote
Old 01-27-2013, 03:57 PM   #7
spray it
Re: questions
I have both two coming threw the fire wall and the two coming from the box on the pass top side. I will try and get some pics later.
