01-25-2013, 09:22 PM | #1 |
Radio fuse keeps blowing. Help please!
Okay so about a month ago i put in a new radio. Its one of those digital ones that has that "factory" look to it. It has worked awesome. The other day i ramdomly blow a fuse and now evertime i change it it blows after about five seconds of being on. The radio has a ground wire, a wire that goes to the spot on the fuse box, and one that goes to the battery for memory. I have checked them all. Even moved the ground to different places.
Has anyone had this problem or can tell me what to do? I am stumped. Do you think it could be getting too much voltage from the memory wire and i should put some kind of resistor on it ? Or maybe i need to add some grounds from body to frame? Any input is appreciated! Posted via Mobile Device
1967 SWB C-10 1972 Blazer 4x4 2011 Silverado |
01-25-2013, 10:00 PM | #2 |
Re: Radio fuse keeps blowing. Help please!
Try posting in the audio section.
Sounds like a bad ground though. |
01-25-2013, 10:24 PM | #3 |
Thanks i will move it there
