Old 01-25-2013, 10:32 PM   #1
bobuilt
bobuilt's Avatar
conversion from 5 on 5 to 5 on 4.75
Does anybody know of a front rotor conversion for my truck to go from a 5 on 5 bolt pattern to a 5 on 4.75 bolt pattern
bobuilt is offline   Reply With Quote
Old 01-25-2013, 10:35 PM   #2
Beetle
Beetle's Avatar
Re: conversion from 5 on 5 to 5 on 4.75
(4) 1.25" (32mm) 5x127 (5x5) to 5x120.65... (4) 1.25" (32mm) 5x127 (5x5) to 5x120.65...
Had these on my Jeep Cherokee for a while, albeit they were just spacers and never had a bit of a problem with em. They should work great!
Jason
TEAM C10 HOT ROD POWER TOUR
689 Short Step
68 Step
Trucks Sold: 70 GMC, 72 K5
Members met: Andy4639 GCncsuHD CSGAS zicc1835 hotrod farm truck Mingrao Bhelton brenthiggins
Beetle is offline   Reply With Quote
Old 01-25-2013, 10:56 PM   #3
bobuilt
bobuilt's Avatar
thanks for the info. I was hoping to go with just rotors, and stay away from adapters. I'll put the info in my data base.
Old 01-25-2013, 11:11 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
CPP and McGaughy's both sell a big brake kit that has 5x4.75 rotors.
Keith
Convert to disc brakes.
Old 01-25-2013, 11:18 PM   #5
ruggles
This a picture of a jig for redrilling hubs and axles. You can do it with a good drill press however the jig is best made at the machine shop. I have the numbers if its what your after.....ruggles[IMG][/IMG]
ruggles is offline   Reply With Quote
Old 01-25-2013, 11:52 PM   #6
DesertCat
DesertCat's Avatar
Yes, please share that one
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 01-26-2013, 12:20 AM   #7
ruggles
Check the numbers before you use it. I haven't used this pattern yet.On some axles or hubs you may have to weld a hole or two. probably not in the case.....ruggles[IMG][/IMG]
Old 01-26-2013, 12:25 AM   #8
DesertCat
DesertCat's Avatar
Talking Re: conversion from 5 on 5 to 5 on 4.75
Very cool! Thank you and welcome to the forum!
edit - just saw you joined a year ago but welcome to your 5th post
Old 01-26-2013, 10:31 AM   #9
cleanfreak
cleanfreak's Avatar
I've done it with all stock components , let me know if you want more info on it. What year is your truck?
cleanfreak is offline   Reply With Quote
Old 01-26-2013, 02:23 PM   #10
bigblock68
bigblock68's Avatar
performance online has a 5 on 4-3/4 rotor...pt#5100
bigblock68 is offline   Reply With Quote
Old 01-26-2013, 06:39 PM   #11
BarryB
BarryB's Avatar
I'm interested, did you use all off the self stocks parts??
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 01-26-2013, 06:58 PM   #12
lolife99
lolife99's Avatar
Those are the rotors they use in their "drum brake spindle" conversion.
Keith
Old 01-27-2013, 08:47 AM   #13
bobuilt
bobuilt's Avatar
I would like to thank everybody for the great help. I have taken all the info and stored in my data base and will be checking it all out. Thanks to a great following. BOBUILT
