FYI Edelbrock valve covers
Tried putting on a set of Edelbrock aluminum valve covers on the truck and while they will go on, they don't fit. My truck is 350 4X4 and the height of the covers causes them to rub on the firewall. Just an FYI
Chuck
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible. |
its all about the +6 inches
Interesting. Have you looked at your tranny mount lately? I have found that if the mount is fallig apart, the engine will tilt back a bit. Also, the poly ones are a bit taller and might be just enough to get your new covers on.
What ones did you get? |
I don't have any problems with mine?? There's lotsa room between valve covers and firewall. Do you have the engine mounted in the 6 cyl position or something?
"Negative people always seem to have a problem for every solution" |
My small block is mounted in the 6 cyl. position on my 67, and I have Edelbrock alum elite covers. I had to gently push in my file wall in two small areas to get the covers to clear.
72 C10 Cheyenne Super Full trim Factory tach dash A/C dash Factory tilt 350 / 350 power train - with Edelbrock components. |
#5 | |
Bloo
all SBC 4x4s have the engine in the I6 position from the factory
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
Edelbrock HP #4249...took them back, don't reall want to dimple the firewall and I don't know how much I would have to dent it in. I've already busted a rotor cap against the firewall when I was hauling wood on a friends farm. Don't know if a comb. of the frame twisting, old body mounts and old motor mounts would have caused it....probably. Have an HEI in it and ended up hacking the back side of the wire retainer ring off.
