Old 01-26-2013, 12:31 AM   #1
Scott>72-GMC
Scott>72-GMC's Avatar
How to remove??? Please help
I realized my last post might resemble the guy that wants to remove his side trim. I'm trying to transplant trim off a parts truck need to know the best way to remove it damage free thanks
Scott>72-GMC is offline   Reply With Quote
Old 01-26-2013, 12:40 AM   #2
Mister-B
Re: How to remove??? Please help
Well, the pieces that are on the bed are pretty easy, since you can reach under and unscrew each cap that's attached to the moulding clips. Then, the moulding just falls off. The tailgate moulding comes off by using a small flathead screw driver on the bottom edge to sort of POP it out a bit as you go. Ten reach behind and twist the clips until it slides away from the lips. The two end pieces have an acorn nut that unscrews from the other side of the tailgate.
As for the other moulding pieces, I don't know how to get it off and keep it usable
Mister-B is offline   Reply With Quote
