Old 01-26-2013, 10:28 AM   #1
Goldfinger
Goldfinger's Avatar
No start condition, electrical
For the past week its been giving me a hard start condition as in the solenoid will engage but after a few and then many turns of the key it would crank. i replace the ignition switch behind the dash now im getting not even the solenoid to engage. pulled the starter bench tested it it worked just fine. I did short something while i was removing the clip but the only thing i noticed wasn't working is the seatbelt buzzer but its back on and working. I'm puzzled.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 01-26-2013, 11:05 PM   #2
pontgta
pontgta's Avatar
Re: No start condition, electrical
If you have a multimeter. I would check voltage at the starter. when you replaced the ignition switch .. you have to make sure it's set right, so the rod will actually engage. ... I would have tested the starter on the truck.
pontgta is offline   Reply With Quote
Old 01-27-2013, 08:29 AM   #3
Goldfinger
Goldfinger's Avatar
I cracked the starter housing while checking it. So the starters brand new. still same condition. i put a starter switch on th starter. but can't get power to the coil.
Old 01-28-2013, 05:37 AM   #4
Goldfinger
Goldfinger's Avatar
Took it to the mechanic, it was alot of everything. no grounds, old rotted wires and a tricky switch.
Old 01-04-2014, 12:36 PM   #5
willy41
willy41's Avatar
Great pics with your post - I really like how your girl friends change every time I refresh the page !!
Mama Truck: 1996 S10, 4 cyl, 5 spd.
Papa Truck: 1973 Cheyenne Super 20, Camper Special, 3/4 K20 350, manual.
willy41 is offline   Reply With Quote
Old 01-06-2014, 08:17 PM   #6
willy41
willy41's Avatar
I'm having the intermittent Failure to Crank problem. I dropped the starter down to better check the terminals. I also jumped the Bat to the Start and it seemed to work ok. The Start terminal did not show voltage when the Ign Switch was moved to the Start position. So now I am trying to get at the switch on the column.
[IMG][/IMG]
Is it possible to get the switch out of there without removing the column?
If so, do you pull the connectors off first or what? Thanks in advance.
