Old 01-26-2013, 04:09 PM   #1
sumtercleaner
sumtercleaner's Avatar
center support bearing removal?
How do i remove the support bearing off the front drive shaft piece? Looks like i'd remove a bolt out the back side - removing the rear yoke??? If so is it regular left hand threads?
sumtercleaner is offline   Reply With Quote
Old 01-26-2013, 07:34 PM   #2
sumtercleaner
Re: center support bearing removal?
Went ahead and pulled the whole driveshaft out. Does the center u joint have to be pressed out?
Old 01-26-2013, 11:52 PM   #3
hayhauler71
hayhauler71's Avatar
yes it does then remove bolt than replace support bearing assembly. Make sure you keep the shaft in phase
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 01-27-2013, 11:08 AM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
Not just in phase, exactly the way it was ballanced. Mark everything!
Remove center ujoint from bolt on yoke, remove bolt on yoke (it shouldn't just slide off), remove rubber from bearing.
If you have a nice tubing or chain vice you can clamp the shaft down as close to the bering as possible and try to beat it off with a hammer and punch. If it doesn't move after a few good hits cut it off! To prevent bending the stub.
You can probably use a deep well socket and a hammer to put the new bearing on. Being carefull to only hit the inner race.
brad_man_72 is offline   Reply With Quote
Old 01-27-2013, 11:13 AM   #5
brad_man_72
the boat guy
If you have a driveline shop handy it never hurts to have them check the ballance after.
I've never seen a shaft go back together and have the ballance not change a little.
They will also notice bad ujoints, ujoints not properly shimmed, loose yokes, worn pinion yoke, bent tubing, bad welds, and other stuff someone who doesn't spend 40hrs a week staring at driveshafts wouldn't notice.
