Old 01-26-2013, 08:18 PM   #1
LDO
LDO's Avatar
Front spring shackle help
I purchased this rebuild kit for my 57 front end. http://www.classicperform.com/Store/.../5559SHK-F.htm
I am a little concerned because it doesn't look like the old stuff I removed. In particular, the threaded pins. My old stuff had nuts on the end of the threaded pins. The new pins don't extend past the shackle plates. Am I to assume that the center (long carriage bolt) bolt keeps the shackle plates squeezed together and that's it?
This kit didn't come with any instructions so I got nothing to reference.
Also, is anyone familiar with torque values for the hardware on the front axle? Didn't find anything in my assembly manual except for the ubolt nuts.
Thanks in advance.
LDO is offline   Reply With Quote
Old 01-27-2013, 02:34 PM   #2
_Ogre
_Ogre's Avatar
Re: Front spring shackle help
you are correct, the long bolt holds it together
my rears are the same, it doesn't look very stout, but it works
shop air compressor timer
Old 01-27-2013, 02:49 PM   #3
mr48chev
mr48chev's Avatar
Your old stuff may have been replacement pins from some vendor who put the nuts on them as part of their design. The ones you have appear to be the factory style but LMC does show a different second series shackle that doesn't appear to use the threaded pins.
http://www.lmctruck.com/icatalog/ca/full.aspx?Page=91
My ongoing truck projects:
Old 01-28-2013, 05:35 PM   #4
LDO
LDO's Avatar
Any idea what the torque value would be on this center bolt?
