Which motor mount?
I'll be dropping a SBC into my '52, stock frame, TCI MII front suspesion, power rack, typical mounting plates on the frame. Which motor mount(s) will work best, the pipe-type or something else? I've dont some measuring, it seems the mounts will be right at the MII mounting place on the frame...possibly. Any help (maybe with pics)? Thanks for all replies.
Re: Which motor mount?
Your other option is biscuit style mounts. I bought these from chassis engineering. Their instructions for locating them didnt work for me, but they are easily adaptable. You will need the cp-1160g to go with your boxed rails. I chose this style because of their simplicity.
http://www.chassisengineeringinc.com/page11.html Posted via Mobile Device
My Lost and Forgotten build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=442712 |
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
sbc w/68 chevy truck motor mounts and my fabbed mounts off the mustII x-member
![]() ![]() parkwood might post his motor mount pics, i like them too
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Your motor mount points on the block do sit above the crossmember with the MII setup making it easier to use the MII crossmember to hold at least one end of the mounts.
Ogre's setup leaves a lot of room for exhaust clearance which is a big plus.
Anyone use the pipe type?
The ones in my 55 GMC are built like that except they 90* back over the frame and are built out of 2" X 1/8" flat stock with pipe spacers for the SBC motor mounts, I built them to bolt into X member and frame.
I could not find any pics, but they have been in there for 6 years and over 50K miles and the motor mounts, and are still working great.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
