01-27-2013, 07:52 AM | #1 |
Exhaust sound of a mustang GT Cobra
I probably should have crawled under a mustang to begin with but has anyone come up with an exhaust setup for their smallblock truck to duplicate the GT sound? I have Flow master 50's just before the axle fed by headers and 2.5" pipes. And 2.5" tailpipes shooting straight out the back and this setup does not produce the same idle nor acceleration sound.
I am not a Ford guy but the Cobra GT's stock sounds better than my 2005 C6. Anyone know how to get the GT sound? Pipe size, crossover, mufflers, where to place them, etc? |
01-27-2013, 09:41 AM | #2 | |
Re: Exhaust sound of a mustang GT Cobra
Some engines are just unique the way they sound. You can replicate the exhaust but still not get the sound IMHO.
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
01-27-2013, 10:02 AM | #3 |
Most of the engine sound comes from the air flow into and out of the head (most of the sound made by combustion). Changing the intake manifold or adding headers will change the air flow and change the sound. The head combustion design and valve placement and size will also change it.
1972 Custom 10 Deluxe- original paint, interior- 72k miles http://www.cardomain.com/ride/2466316 Cheap, Fast or Good. Pick any two. 1990 Eagle Talon AWD 1991.5 W250 CTD 1992 Cushman Truckster- Haulster |
01-27-2013, 10:46 AM | #4 |
working at muffler shop for 25 years, I hear that question alot. Hey can you make my mid 90's chevy truck sound like a mustang. I even had a guy bring in two mustang mufflers to put on his old chevy car. My only response is you better buy a mustang. I did build a system for a 58 chevy truck that the guy instlled a complete mustang dtiveline in. I even installed all four factory comverters in the system. sounded awesome
01-27-2013, 10:53 AM | #5 |
2WD Jimmy
That Cobra has a dual overhead cam motor, hard to duplicate that. However you can put in an X-pipe and a set of Dynomax mufflers, and that will get you alot closer.
01-27-2013, 10:56 AM | #6 |
My Carbon Footprint
Same reason why Ferraris sound like ferraris. It's just the combo of really small, high horse motor and short system.
01-27-2013, 11:04 AM | #7 |
install new roush crate engine and you b good
01-27-2013, 11:22 AM | #8 |
Well, probably unlikely I will buy a mustang and what model of Dynamax or is there only one?
Also the sound of a big block is nice but would require more than an engine change since I run a 4wd with a 350 turbo with an np208. On the Roush engine, Jack Roush is from Manchester, Ohio, about 30 miles from me on the Ohio River and has a mustang show each year in this gutted town of maybe 1000. He will autograph about any mustang when he makes his yearly appearance there. Thanks for your responses. |
01-27-2013, 11:23 AM | #9 |
I can hear a mustang coming from aways away they have a very distincted sound and i can see how alot of people can like the sound,
but personally I think a healthy chevy sounds sooo much better i dont understand why somebody would want there chevy truck too sound like a mustang??
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
01-27-2013, 11:45 AM | #10 |
the boat guy
Cam and compression ratio make a huge difference. Also different firing order.
I loved working at honda, can I make this cruiser sound like a harley? Just start talking about twin pin cranks and watch their eyes glaze over lmao. Oh you just meant loud, yeah that's easy. Posted via Mobile Device |
01-27-2013, 05:45 PM | #11 | |
You can get some elements of this sound by balancing the duals with crossover pipes, run a big ass single instead of duals, or using 180 degree headers to even out the exhaust pulses. But in the end you won't duplicate the sound of more valve area and lower lift of 4 valves with higher lift, less valve area with more overlap and float that a push rod engine produces. I've heard Vettes with 180 degree headers that come close, flat crank small blocks that get close, and an 8 into 1 header on a smallblock in a sandrail that just sounds alien, but 32 valves, DOHCs and flat cranks introduce distinct elements into the exhaust note. |
01-27-2013, 06:05 PM | #12 |
My Carbon Footprint
The F355 I drove was a very small V8.....like a 3.5L or 218ish CI. My point is that when you get the cylinders, cubic inch that small with that much power, they start sounding more like a high end road bike than a high end car. That also helps them rev to the moon.
01-27-2013, 07:32 PM | #13 |
Wish I could get my 350 to give the sound of my old Subaru brat
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. " |
01-27-2013, 07:40 PM | #14 |
Really? Really? You want to sound like a Mustang? WTF
I'd rather sound like a Healthy Chevy V8. Pretty sad when a Chevy guy wants to sound like a Ford, pretty Damn Sad. One main reasons they have "that sound" is their firing order combined with the exhaust system.
1968 SWB. GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators. Remember, no matter where you go, There you are. Gary |
01-27-2013, 09:16 PM | #15 | |
01-27-2013, 09:18 PM | #16 | |
01-27-2013, 09:23 PM | #17 |
I have a 2012 GT that I think sounds great in stock form. It's funny though you browse the Mustang forums and it seems like a lot of guys want to change the exhaust.
01-27-2013, 09:29 PM | #18 |
01-27-2013, 10:39 PM | #19 |
the boat guy
One easy step to make a chevy sound like a ford.
Pull the coil wire.... har har har! Posted via Mobile Device
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
01-27-2013, 11:06 PM | #20 |
71 K20 64 GMC mud truck |
01-27-2013, 11:16 PM | #21 | |
01-27-2013, 11:39 PM | #22 |
Actually it would be four wires and re- producing a boxer engine would still be hard to do
01-27-2013, 11:45 PM | #23 | |
This is coming from someone who has owned 17 Subarus and could probably assemble an EA82 engine in pitch darkness, so it's no knock on Subaru. |
01-30-2013, 01:01 AM | #24 |
I would like my truck to sound like master of puppetslol
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
01-30-2013, 01:54 AM | #25 | |
the boat guy
