01-27-2013, 12:16 PM | #1 |
Psi harness where to mount computer
Looking for pictures of how some of you mounted your computer. Its hard to find a plqce under the dash with the vintage air unit taking up almost all of the glove box space.i want it out of sight but accessible any input would be appreciated.
Posted via Mobile Device |
01-29-2013, 06:54 PM | #2 |
WTB this ad
Re: Psi harness where to mount computer
i put mine under the hood... i also have vintage air.
01-29-2013, 07:03 PM | #3 |
Do you have any pictures?
01-29-2013, 08:23 PM | #4 |
1965 Chevy C10, 2005 4.8L/4l60
Put it in the heater box under the hood. You will need to get an fbody trans dipstick tho
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
01-29-2013, 10:02 PM | #5 |
WTB this ad
It's a super crappy cell phone pic... but... anyway...
Clears the master cylinder, the washer bottle and the hood hinge... My brother's has been like this for over 2 years and hasn't had any issues. |
01-29-2013, 10:06 PM | #6 |
WTB this ad
another shot... hard to see exactly how it's mounted from this side though...
01-29-2013, 11:10 PM | #7 |
A day late and $1 short...
I put mine in the area where the glove box was located... and routed the harness through a hole in the fire-wall/trans-tunnel.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
01-30-2013, 08:46 PM | #8 |
Mine is mounted on the inside of the left corner of the firewall behind the dashboard. The photos are before and after the finish. It's hidden from view by an A/C vent.
01-31-2013, 02:08 PM | #9 |
behind glove box....psi leaves lots of wire....
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
01-31-2013, 05:28 PM | #10 |
I bolted mine to a piece of aluminum and used rubber spacers between the aluminum and firewall. I have the vintage air as well.
Blazer Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=483399 |
01-31-2013, 10:19 PM | #11 |
Here is where I put mine. It's under the dash below the glove box. The heater tube clears the wire harness ok. The picture makes it look like its tight to the wires but that was before I wrapped the wires.
Posted via Mobile Device Posted via Mobile Device
This is my Build A 5.3L 1965 C-10 Fleetside http://67-72chevytrucks.com/vboard/s...d.php?t=502100 |
01-31-2013, 11:10 PM | #12 |
I mounted mine on fenderwell,easy to get too.
02-01-2013, 09:15 AM | #13 |
02-01-2013, 12:33 PM | #14 |
Right now they are laying on top of the computer secured by a zip tie. My plan is to fabricate a new shallow glove box insert to mount the fuse/relay panel, OBD II connector, and the control box for the electronic speedometer. Just need to get a day to work on it, when I get it done I will certainly post pics.
02-01-2013, 12:53 PM | #15 |
Thank you i think i might just mount my computer on the firewall behind the motor and run the fuses and OBD II inside.
02-01-2013, 01:14 PM | #16 |
wow...you're not even trying...not sure why you'd need to access the pcm that easy?...but, whatever...I didn't want my engine bay looking like a bag of snakes...so the only wires you can see are the plug wires..
02-01-2013, 04:46 PM | #17 |
I see the injector wires, the alternator wires...
02-01-2013, 05:01 PM | #18 |
02-01-2013, 05:11 PM | #19 |
Looks sweet!
02-01-2013, 05:17 PM | #20 |
thanks...I'm hopin to get a ls1/ls6 intake on there to clean it up some more...
02-01-2013, 05:59 PM | #21 |
I'd like to clean up under the hood on my S10 but it's gonna have to warm up some before I can.
02-01-2013, 06:00 PM | #22 |
By the way Buck that harness I bought off of you works perfect from the git go. I can't thank you enough for your help! Ray
02-01-2013, 08:24 PM | #23 | |
02-02-2013, 07:51 AM | #24 | |
02-02-2013, 07:53 AM | #25 |
