72 swb to trim or not
Father/ Son type project.Brief plan but we know hoe those turn out sometime
![]() 1. Get it running and make it mechanically safe. 2. Lower it and put a set of Rally's on it and put my son's business logo on the doors and drive the you know what out of it. I have a complete set of OEM trim for it but I thought that would look kind of goofy with 40 yr old paint and knew trim. If we shave the existing trim and repair the holes we have body filler all over or maybe I get some older trim to finish it up but that would probably take a while and we want to get it Rollin . Opinions and suggestions would be appreciated.Sorry about the upside down pics.How do I turn them right side up? Thanks Kirk Posted via Mobile Device Posted via Mobile Device |
![]() Join Date: Oct 2009
Re: 72 swb to trim or not
buff the paint up as good as you can get it, run your good trim until you get the repaint down the road. It will not look odd because the trim is nice - I understand what you're saying - but I think new trim on old paint would look much better than filled holes simply because of concern over new trim not matching the condition of the truck. MANY of us are driving (or gracing jack stands) with works in progress. My 2 cents.
Here's the real question - if you were finishing up the body right now and applying a slick paint job, would you want the trim or filled holes? If trim, then leave it as is. If no, then you might as well fill them now. Personally, I think it looks better with it, but that's just personal taste - many folks like it without the upper trim. |
The Older Generation
Like this... ![]() I don't know what you use for a image program but there should be a "rotate" selection in it somewhere. LockDoc
Thanks LOc Doc,I was posting that on my Ipad and still haven't figured out all the the tricks to it, but I'm starting to like this Apple stuff.
#5 | |
Cluster King
![]() Join Date: Nov 2012
I have an ipad and had the same problem. You have to turn it around 180 degrees to take the photos right side up. Also like LocDoc said, you should have a rotate feature on your image program. |
Moderator
![]() Join Date: May 2007
These trucks look great with upper and lower trim. I would run it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
I vote for having trim.
1971 chevy c10 ECE 4.5/6 dropped 1970 suburban ECE 4/6 Dropped 45K original miles so far 1948 Ford Sedan 1941 Dodge COE 1932 ford roadster the rest are normal drivers |
That settles it,I'm going with the polish as best I can and trim it.This actually is an original Highlander pkg truck for whatever that's worth but we just want to make a solid driver out of it and throw some PB goodies at it and make it comfortable to drive.
Thanks for the reply's |
There's nothing wrong with having new looking trim, and old paint. In fact, you can run new looking trim, bumpers, mirrors, emblems, grille, etc. and old patina paint, and it's kind of the hot thing right now. With the economy in the crapper, it's a little more sensible to shine and replace smaller pieces and leave the paint, than to spend thousands on a paint job
Here's my 70 c10 before and after I reinstalled the lower trim. Personally I think they look WAY better with at least the lower trim.
![]() ![]() Posted via Mobile Device
1979 Silverado C10 Shortbox - Photo Album 1977 Silverado K20 Camper Special - Photo Album 1972 C10 Custom Deluxe Highlander - sold 1971 Cheyenne Super Longhorn -sold 1972 Cheyenne Super SWB 4x4 -sold, bought back, sold again... I'm dumb. 1970 Chevy C10 SWB "Sprout" -sold 1972 Cheyenne K20 -sold 1969 GMC Shortbox Stepside 4x4 -sold 1972 GMC Jimmy 4x4 -sold Last edited by Tomahawk30; 01-27-2013 at 10:47 PM. |
![]() Join Date: Apr 2012
If you decide against the trim, let me know. i'm looking for some. Woodgrain or black lowers?
#13 | |
Wow, ya know. I gotta say, that does look better. Seeing it before and after like that really shows it Posted via Mobile Device |
#14 |
Sorry Kirk,
You probably are not going to like this but... Like we said last year when you listed this for sale. It is a fairly rare truck being a big block SWB Highlander Promo package "C" truck. The upper moldings are part of the "C" package and the lowers are part of the Custom Deluxe package. The white on white is not often seen and the blue plaid along with the black bits tie everything together nicely. This truck needs to be restored. Thought you had seen the light when you pulled the sale off CL and the classifieds here after finding out what it was. Did you get the original block for it? Even if you do not have the original block a replacement can be found and if you are so inclined a 454 or a stroker could look just as stock. An O/D trans like the 7004R is nice to have and tames the gas consumption if you do your part. :-) If the all white is too much maybe filling in between the upper and lower body side moldings with 510 medium or 523 dark blue as is sometimes seen. It is incorrect but nice and period too as would a set of slot wheels! Just in case you missed it before here is my Highlander blurb and a couple of pictures. Highlander Plaid was a trim only option based on Z62 or Z84 (Blazer only) optioned vehicle. In addition promo packages A,B and C were offered that bundled several options in addition to the Plaid trim. Thus a promo package truck was a Highlander but a Highlander was NOT ALWAYS a promo package equipped truck. Highlander trim codes All include black dash pad, steering column (with or without tilt) and carpet. In addition the door panels, visors, console (Blazer only) and seat belts were parchment (white). Seat vinyl was also parchment and the insert color is determined by the specific code. So the only variable color keyed component was the insert color of the seatcovers. >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Pickups Custom Deluxe Z62 mandatory option green 613 blue 611 gray 604 orange 618 >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Suburbans Custom Deluxe Z62 mandatory option green 647 blue 642 gray 639 orange 651 >>>>>>>>>>>>>>>>>>>>>>>>>>>. Blazer Cheyenne (CST) Z84 mandatory option green 680 blue 677 gray 671 orange 686 >>>>>>>>>>>>>>>>>>>>>>>>>>> Promo package codes A= YG6 Plaid Trim, Special Wheelcovers C10 (PA1) or Chrome Hubcaps C20-30 (PO3), Chrome Front Bumper, Upper (Belt) Molding, Door Edge Guards and Below Eye-Line Mirrors. B= YG7 Adds Turbo. Automatic Trans., Power Steering and Tilt. C= YG8 Adds A/C and Tint.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#15 |
Trim looks better
My Build thread 1969 Short wheel base http://67-72chevytrucks.com/vboard/s...d.php?t=468622 My 1969 Short wheel base Pantina truck http://67-72chevytrucks.com/vboard/s...d.php?t=561603 Posted via Mobile Device |
#16 |
I really like the white trucks with uppers and lowers. IMO they look very classy that way, and white is very forgiving of paint flaws. On the other hand, white without the trim looks very plain unless the white paint is flawless with a tint to it. Just my opinion, but I'd love to have that truck to put back to something close to original.
1979 Silverado C10 Shortbox - Photo Album 1977 Silverado K20 Camper Special - Photo Album 1972 C10 Custom Deluxe Highlander - sold 1971 Cheyenne Super Longhorn -sold 1972 Cheyenne Super SWB 4x4 -sold, bought back, sold again... I'm dumb. 1970 Chevy C10 SWB "Sprout" -sold 1972 Cheyenne K20 -sold 1969 GMC Shortbox Stepside 4x4 -sold 1972 GMC Jimmy 4x4 -sold |
#17 |
Hey Kirk, I kinda read this earlier, made a post, and haven't been back for a bit. A highlander, eh? What a great truck, a swb highlander, at that. With that little tidbit, I'm am on board with what Tim said - if there was ever a candidate for a resto, this would be it. Much more rare than a cheyenne super or anything like that.
I'd love to see the SPID, more pics, etc... ![]() ![]() ![]() |
#18 | |
#19 |
Yo Jocko and Tomahawk30, The SP is in my previous post pics when I was gonna sell it. We' gonna go with a combo of looks,a little old that being the interior with the Blue Plaid ,some knew being the PB and trim and original with the paint. Just got the heads back and gonna pull the block and get it and the eng bay cleaned up and put back together and go on from there. I know a lot of the purist would like original restoration but my 23 yr old likes the old school shop truck look, I'm just glad he doesn't want a Tooner
![]() Posted via Mobile Device |
#20 | |
#21 |
Sorry SSTIM,I didn't see your previous post of the SP.Is there a vendor on here who sells seat covers and who the go to vendor for carpet kits?
#22 |
Found your original post from when you picked this one up, and now I REALLY think its worthy of retaining as much originality as possible. I see that you already have a white truck with all the trim, so my earlier comments were probably just preaching to the choir!
#23 |
OK, I thought the pictures had posted. Lets try again.
So how do I add a "Restore It" poll? :-) EDIT: The SPID is Stickman's truck the other pictures are incentive pictures of the blue/white/black Highlander trim option.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 01-28-2013 at 12:33 AM. Reason: more info |
#24 |
Tim, as long as poll options are:
a) restore it (we're sorry, option "a" is unavailable at this time...) b) give it to jocko c) sell it to jocko d) restore it then give it to jocko Holy cow, what a great truck. I don't see an NL2 RPO - but is that the aux tank gauge switcher above the driver's a/c vent there that I see??? Maybe there just wasn't any room left to list that option.... Holy cow. EDIT: Oops - disregard, I assume that is the man throt. Last edited by jocko; 01-28-2013 at 12:40 AM. |
#25 | |
