Old 06-11-2003, 07:57 PM   #1
Russell
Professional Grade
Russell's Avatar
Ah Ha!!
LOL! I opened my Master Cylinder, and found out why my brakes were not working
First off, that thing was a MESS! I am amazed that it worked at all before! Anyways, I washed it all down and found that the rear brake seal was broken!
I called NaPa and they are gonna try to get me just a seal without the master cylinder kit, if not I have a smaller, older one that I can use. They also are gonna try to find me a front left signal light. Hopefully my mother gets back with my Blazer soon, or they'll close on me... If I can get both these parts, all I gotta do is rotate the tires, while checking the rest of my brake pads / drums, do a little more work on the horn, then I can get insured and on the road by the end of the week!
Pictures:
Yuck! Messy!
These parts (other than the springs) are suppost to be silver!
The culprit! Replace this, and my brakes should be good!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 06-11-2003, 08:49 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
that was worse than the inside of the motor of my truck lol
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 06-11-2003, 08:50 PM   #3
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Here's a tip for ya i do this every time i do my eng. oil cng.@ 5k i also cng my brake fluid in the master cyl.
I have an old turkey baster that i use to suck the fluid out and then i wipe out the reservoir with a clean rag & then put in new fluid
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 06-11-2003, 08:51 PM   #4
Russell
Professional Grade
Russell's Avatar
Would you have to rebleed the brakes if you did that?
Old 06-11-2003, 09:21 PM   #5
87 STEPPER
87 STEPPER's Avatar
No,
Because you never introduce air into the system cause there's always fluid in the M/S and the lines.
Provided you don't depress the brake pedal after you remove the fluid from the M/S.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
Old 06-11-2003, 09:45 PM   #6
Russell
Professional Grade
Russell's Avatar
Alright, sounds good! I'll probally get into the habit of changing my brake fluid every second oil change...
