01-27-2013, 06:35 PM | #1 |
Thermostat housing on sbc 400
The PO had a cheapo chrome housing which started leaking recently. Pulled it off today and there was a lot of grimy stuff in there and in the threads of the manifold. There also was just rtv and no gasket.
Two questions: Should I use a gasket w/ rtv on each side(what I always thought you should do) and what is the best way to clean the threads out? I don't want to get the bolt cross threaded in the manifold, that would not be good. Thanks. |
01-27-2013, 06:56 PM | #2 |
Re: Thermostat housing on sbc 400
I have found that it seems only the chrome housing that have a rubber O-ring seem to seal well, the ones without and just use a standard gasket allways seem to leak and I have had that the surface had warped and made them leak.
That said I would coat both sides of the gasket with a then layer of sealant and a tap would clean the threads out the best. Posted via Mobile Device |
01-27-2013, 07:03 PM | #3 |
I replaced the chrome one with a more cast-looking one. It's a Murray from O'Reilly so we'll see how it does. I'll lightly coat each side after I get those threads cleaned out.
Thanks. |
01-27-2013, 07:04 PM | #4 |
felpro 35562T gasket..
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
01-27-2013, 08:34 PM | #5 |
Thanks Pop's. Go with that over the one that came with the housing?
