Dash light bulbs keep buring out?
Have a 64' with guages - I keep replacing dash bulbs and they burn out in a day - Any idea what is going on?
Who Me?
Re: Dash light bulbs keep buring out?
What is the output of your alternator? Im thinking over voltage.. maybe?
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Cluster King
![]() Join Date: Nov 2012
Exactly, if you have to much voltage that will cause this problem. You may have a voltage regulator that stuck. Do you have a volt meter? get one and check battery voltage with the engine running. You should have between 13.5 and 14 volts at idle. If you are seeing 15 + volts, then I would suspect a sticking voltage regulator. Do you have the correct amp fuse for the dash lights. I think they are only 5 amps if I remember.
If you check the voltage, and it seems good, it is likely a ground problem. When you have too low voltage, the bulbs will also burn out fast.
Will check it out - thanks for the help - I do have a valtage meter - but you would think I'm in 2nd grade when it comes to using it - Might as well being speaking greek
