Old 06-11-2003, 09:15 PM   #1
Adron67
Ford 9 inch rear ends
I want to put a Ford 9 inch rear end in my 67 chevy pickup. Right know i have a stock chevy rear end 6lug and i was wonder what would be the best way to convert it to a 9inch with 3.50 gears and posi
thanks
Adrian
Adron67 is offline   Reply With Quote
Old 06-12-2003, 09:43 AM   #2
crazy longhorn
Fabricate till you "puke"
check out this conversion kit......its listed for 73 up 12 bolt diffs, but should work on the ford rear also http://www.classicperform.com/produc...ersion-Kit.htm
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
